Wheel arch insulation (1 Viewer)
Jul 10, 2014
179
57
Cheltenham
Elddis Encore 255
3 years
The rear wheel arch protrudes into the base of our wardrobe and being the coldest place gets covered in condensation. The arch is plastic and I wonder if someone could suggest the best type of insulation to cover it with?
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If there's nothing else down there put a false base in the wardrobe about an inch above the wheelarch then stuff the area below with loft insulation. If you need to cover just the wheelarch itself use inch-thick dense foam & glue it to the plastic - it will be sufficiently flexible to follow the curve of the wheelarch.
Dec 12, 2010
5,407
21,548
Cumbria
since 2011
Was thinking about doing something like that with ours in the bathroom, taking the cover off and spraying it with aerosol foam.
