What's this thing on my battery? (1 Viewer)
marksmith
33
19
Hampshire UK
Low profile coachbuilt
Since 2008. Owned since July 2013.
Hi folks,
Can anyone tell me what this thing is/does on the positive terminal of my starter battery? (Roller Team on Fiat Ducato, 2004.) The negative terminal has a fairly straightforward terminal block on it - with connections to the chassis earth and leisure battery I presume - but the one above is on the positive terminal and looks much more complex than just a terminal block.
Does it relate to the split charging system or fridge relay or something like that?
Broken Link Removed
(As an aside, the reason I'm looking at this is that we have just done our first tour with our own motorhome - two weeks in Scotland. On the way up and the way back the van failed to start after a stop of literally about two minutes - symptoms like a flat battery. On both occasions a jump start fixed it and all was well but it was completely unclear what caused it to happen. During the fortnight we must have stopped/started the van 50 times and had no trouble at all. Yesterday I discovered that the negative terminal was very loose - just lifted off - so I hope/suspect that's the problem.)
Thanks!
-Mark
jb0371old
465
408
Norfolk
Autotrail
1 year
probably just an adaptor to keep the wires all neat and tidy. Making it easier to connect and disconnect all the bits.
Just my thoughts, not an expert by any means::bigsmile:
43,319
49,401
loose neg terminal....definately the problem.
would work fine powering the vehicles electronics but a very heavy load, like the starter motor, would break what contact there was.
M
marksmith
33
19
Hampshire UK
Thanks hilldweller - that sounds about right.
Thanks jb0371 - but it's definitely more than just a terminal block.
It's definitely a problem. Whether it's the problem remains to be seen but I'm hopeful. Exactly how it would behave would depend on what state of bounced-off-ness it was in at a given moment...
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Yes, but which one !!
Our 2003 FIAT did this on us and I eventually traced it to the main engine<->chassis earth bond under the engine on the near side. Fully exposed to road spray, great move FIAT. Corroded joint on the engine, cut a bit off refit, fine. And with a mass of copperslip good for the rest of the life of the vehicle.
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
You're lucky you could get jump leads to stay on the POS side, mine only just catch onto one of the bolts on that plate as you can't get to the battery terminal and will jump off almost every time I let go of the crocodile clip.
(my newer fiat work van has the battery under the cab floor and two specific jump start terminals under the bonnet which are far easier to use) (hope I've not missed something similar on my motorhome van :Sad: )
Merle
424
226
Wiltshire
Since 2008
I have the same problem on my Peugeot Bryan, has any one tried the cigar lighter jump starters that are advertised? are they man enough for a diesel?
TheBig1
17,619
43,204
absolutely not anywhere near man enough. you are relying on a cigar lighter socket circuit capable of handling just 10amps
a bad earth strap on the engine or loose terminal on the battery will cause this problem. better to fix the problem before it leaves you stranded. very simple for even a basic diy mechanic
first check clean and tighten battery terminals. smear with a little vaseline to prevent corrosion
then check the condition of the earth strap. if it looks frayed or burnt a little at the ends just unbolt both ends, clean the connecting points and bolt a new one in place. the earth strap is a thick wire, as thick as your finger between the engine or gearbox and the vehicle bodywork. its often exposed to the elements under the van where it get road spray and debris on it
as for the bus bar, keep it clean and prevent anything metallic bridging it to any bodywork
43,319
49,401
still cant get my head around these things.
how can something rated at maybe 2 amps (the battery in the box) provide power, through a 10amp cable (fag lighter supply wire), for a starter motor requiring upwards of maybe 400amps.
even a car to car type lead would still only be rated at 10amps
if these things actually work, why do we need such heavy 600amp+ jumpleads
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
Link Removed
better to have these fitted .then make a set of jump leads to fit .
the prison trucks we build on have these as the batteries are hidden behind the cab . makes it easy just plug on then connect to other vehicle . tail lifts etc sometimes use them . but durite have outlets all over the country almost every auto electrician possibly buys off them .
duane0001
792
778
East Coast, North Yorks
Expedition 67 soon!
2021 This time
Link Removed
Those are anderson lead ends, we use em for powering any ancillary equipment on artic trailers
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
yes but they make ideal connections for jumping leads if batteries are buried . make the leads to the plug and have the other plug on your jump leads .
Curtisden
49
19
Near Goudhurst Kent
High top 6m Panel Camper
Newbie but 25 Years towing.
Battery conections
Hi folks,
Broken Link Removed
Thanks!
-Mark
That is the mega fuse.
Have you checked the electrolyte levels? You will have to remove the mega fuse board first carefully after removing the neg. first.
Peter
M
marksmith
33
19
Hampshire UK
That was indeed a problem. The positive terminal is so inaccessible under the scuttle that I was worried the croc clip was going to pop off and bridge it to the metal panel right above it. That would have been messy. Why didn't they just put it the other way round - positive at the front?
I was actually thinking of making a jump start terminal - just 20cm of shaped metal with a hole in one end to attach to a terminal, and heat-shrink sleeving over most of the length of it, and a removable cover over the exposed end.
The cigar lighter ones I've seen (some time ago) were not jump leads but car-to-car chargers. You'd plug them in for an hour or so (charging at say 10A) and then you'd have 10Ah in your battery, which would hopefully be enough to run the starter for 5 seconds.
The battery is the mainenance-free type. Anyway I think the loose neg terminal is very likely the cause of all the trouble. The battery is almost brand new - suspect the fitter introduced this problem.
That's exactly what the AA van had. Quite handy if you are going to use it frequently. I'm hoping not to have to jump start it too often though... plus then your jump leads only work on one vehicle.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
you might get some charge in via a cigarette lighterif you have plenty of time but no way you could start via it ,wiring much to thin
as said the photo is the bus bar and some fuses possibly the additional red wire is connected to the split charge relay
Steve
1,613
2,062
Compton Berkshire
C class
on and off for 40 years
Your main fuses. The + bussbar.
My 05 2.8 Ducato has this set up handy for adding extra wires but not good to fix a jump lead to. The only time I had to jump I undid the battery and pulled it forward so I could get onto the + in a strong bit.
M
marksmith
33
19
Hampshire UK
Well it turns out the dodgy negative terminal was not the only problem. Shortly after replacing it the alternator stopped charging altogether. Removed the alternator, which tested OK. Battery is almost new.
After quite a bit of hunting (and disappointing bad advice from a local specialist!) the problem turned out to be poor earthing: connected a jump lead from the alternator bracket to the battery -ve and it started charging perfectly. The bolt connecting the earthing strap to the gearbox was rusted to pieces. In fact it snapped when I tried to undo it.
New bolt into a conveniently-located and suitably cleaned spare hole on the gearbox and now it's charging properly.
As a precaution I've ordered a second earthing strap which I'm going to fit it between the alternator bracket and the body.
It's a bit of a mystery that the van would start (but not charge) because both the starter and the alternator use the same earth. The starter sounds a lot stronger now though, so I think it was struggling too.
Grumpyfred
Hymer
3years
Message 5 last month :winky:
I had one years back, thought it was a wind up. He said The car would only start if the gear lever was in first, I said you mean in neutral? He said no, try it so I tried it and he was right!
Eventually found it was earthing through the drive shaft and back axle so wouldn’t start without the gears pressing together ( probably in the diff )
New earth stap fixed it!
