What's this switch for? (1 Viewer)
S
Stueysheep
Got my Bessacarr E745 yesterday and there is one switch bo one knows what it's for.
It's a square rocker switch alongside two normal type light switches. It has a green LED in the moddle which comes on when you throw the rocker...
Any ideas, Simpsons didn't know... Said they would ring the previous owner if I am stuck...
Jim
Ringleader
Jul 19, 2007
36,315
130,209
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Could be a few things but my best guess is locker lights, the lighted switch is to remind you that they are on.
S
Stueysheep
Thannks, good suggestion but the locker light is on another switch.
Amymore suggestions please?
wildcamper
3
Merseyside
High Top
i never even notised that i just ashumed he ment the dash :Blush:
Supertractorman
406
Stueysheep,
Think it could be your outside Awning light. ( Mine is situated there, but not illuminated )
David
Oct 14, 2007
3,979
6,197
Rochester
Auto-Trail Mohawk
16 fun filled years
I have a switch on my new Bessie that has a light but it doesn't do anything on the motorhome it's for unlocking the rear doors when it's a van.
scotjimland
2,246
9,751
A Woosh bang
Waste tank heater .. !
Adria 5
1,181
5
adria caravan
hi any pictiure available off the switch ?
ray
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
An outside light. The reason it's illuminated is to show when it's been left on.
Many are not visible during daylight hours & can be left on
adventure
118
somerset
25 years
Hi Stuart
The switch ( I Think ) is for the fan fitted to the rear of the fridge, the fans are normally temperature controlled but also has an isolator switch which is normally by the door with a light on it.
If you remove the upper fridge vent you should be able to see a fan, the fan helps to extract the heat from the rear of the fridge in hot weather.
nick
Phil
226
Herts
10 years
On my Swift the normal type light switch puts the water heater on with mains, the switch by the side with a green led switches the water heater on with gas. May be similar arrangement?
Phil.
Corky 8
29
South West Scotland
off and on since the 70 s
I have Three large rocker switches with a smaller one between them ,inside on the right hand side of the M/H door one is for main lights for the living area,next to that is a switch for the over head door light and inbetween those is a smaller rocker switch for the elec step,and next to that another large rocker switch , which when you switch it on nothing can be seen as its the awning light, if you open the cupboard behind the light it does shine in the cupboard aswell, any Help. Oh on an 04 plate. Bessacarr E720 Corky
S
Stueysheep
problem solved.
It's to switch on a heating probe in the freshwater tank to stop it from freezing... Keeps it above 2 degrees C..
I won't use it, can see it flattening the batery and then frezzing the tank!!:ROFLMAO:
Tony Hunt
214
Wimborne, Dorset
RV A class
Only if your wildcamping and not on a hook up. Be wise to use it normal times. if your laying up for the winter and not on hook up you wouldnt leave water in the tank to freeze anyway.
SwiftGroup
108
Whats the switch for?
We think it may be a switch for the tall fridge freezer. Its an isolator switch for the fridge freezer fan but you generally will not need it as the thermostat on the fan controls the operation.
Regards
Kath
adventure
118
somerset
25 years
sorry but I thought the switch operation was solved:secret:
did someone just copy my post??:Cool:
TonyP
14
Milton Keynes
Whats this switch
had one in my autotrail apparently it is for additional extractor fan for the fridge/freezer during hot periods, if its the same thing.
TonyP
allanbroderick42
green light on dash
hi
on my bessacar the one on the dash with a green light is the air conditiong hope this helps
allan:thumb:
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
Is it for the cloaking device when driving in the LEZ or congestion zone?
May 22, 2008
484
How about a heated collar for your gas bottles, got that on my Hymer ??:Eeek::Eeek:
