Depends on what load you are pulling but on full load the 2k inverter will be pulling 166 A ... flat battery in about 15 min , also a chance of permanent damage to the battery, gels are not designed to give such high currents.
Was thinking of 700w (1200w peak) microwave maybe 10-15 mins.
Just had couple of weeks in France, mainly airs no prob on 12v, for cooking the occasional 240v would be handy, but it's either the haslle / weight of generator or weight of extra bat + inverter :Sad:.
If its only for the occasional use and on a tempory basis you could with big crock clips run it from your engine battery with the engine running the alternator is probably is a 90 amp one and if you run the microwave on medium and not full power it should cope ok.
I used to do something like that when my boat was out of the water and run it of the car.
If its only to run a microwave would it be worth considering one of the 12v portable ones that are now about have not used one but have heard they do a good enough job - just a bit slower than household ones
