What's the cleverest thing you have seen in a MH ? (1 Viewer)
6pm Cowboy
916
South Oxfordshire
none ( yet )
0 - but I live in hope
( Bearing in mind I am new to this )
While at Malvern we were struck by the big Garages at the back of some of the MHs but didn't like the way that always meant it would have a high double bed inside ( couldn't climb up to that sober, never mind pixxed )
But in one MH we looked at the double bed was on hydraulic jacks so YOU could chose how big the garage was and how high the bed had to be....
Clever stuff that.
Spacerunner
607
197
Hampshire
Its the simple things that impress me. ( no, not the missus)
A hinged flap to cover the step well at the habitation door. Curtain rod brackets turned at a slight angle to stop them rattling.
Feb 22, 2008
12,260
45,026
Norfolk
Nearly Tugging
Since 2004
MY wife, she cooks cleans washes opens my cold beers and does all the things a good un should ::bigsmile:
superk
495
57
Devon
Van Conversion now sold
8 years
Hi Graham
Mine's a bit of an oddball and not very exciting:
External security roller shutters for plastic windows. These windows are one of the most vulnerable security points on a van.
Look really neat, fit flush on the outside, wound manually from inside and curl up inside, made by Rolf Seitz, never seen in the UK and cost a fortune.
Can't fit to our present van because it has a sliding door and the wound up shutter (inside) would prevent it opening.
:Smile:
Keith
Feb 22, 2008
12,260
45,026
Norfolk
Nearly Tugging
Since 2004
Seriously Graham, I have a printed laminated card A5 which reads inbold red letters ' HOOK UP
SATELLITE'
When I arrive on site I put this on my dash to avoid any embarrassing moments when leaving.
Larry
43,293
49,250
SATELLITE'
Larry
sorry to go off track but i thought it was worth a mention.
same idea but use a clothspeg if its a crankup dish.
clip it on the dish crank handle and then on the steering wheel when dish in use.
if its on the handle you cant 'forget' to put it on the wheel which you could with a card.
could do the same with the hookup.
not my idea but a good one none-the-less:thumb:
ronald4874
175
6
Poole Dorset
CB 6.5 metres
About 15yrs plus early years in caravan & cruiser
Clever M/H layout
The garage with a double bed over is an abortion, A) it takes up valuable day space B) difficult sometimes to get into.
The one I like is the one with the rear garage with the kitchen and bathroom over. This leaves you with plenty of day space especially if you can use the drop down bed. This bed is for sleeping north/south as opposed to the normal east/west bed, easy to get out of in the night without disturbing your partner.
RonW
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Clever stuff that.
Are you sure it wasn't a sex aid - did you see any straps above the bed ?
May 22, 2008
484
RonW
Each to their own as they say, we love our garage and high bed over and it has two steps up to the bed, how much easier can that get, we also have a drop down bed in the cab area and that requires a short ladder to climb up to it or you can climb in off the settee, again easy.:thumb::thumb:
Kon tiki
487
North Wales
Low Line
I like the garage with the bed over the top, quite a few vans have a bed over the garage which can be lowered. One example is the Chausson, don't see these as being practical as you obivously have to clear out anything high in the garage to lower the bed. Also in my case I would get fumes off my motorcycle as any sort of moving bed would have to have clearance around the edge. My garage seems to keep any fumes from leaking into the van.
You could try looking on the Link Removed to see the internal layouts. Would like another Frankia but they don't come cheap.:cry::cry:
6pm Cowboy
6pm Cowboy
916
South Oxfordshire
none ( yet )
Yes you are right but I wasn't thinking in terms of raising or lowering it all the time, more just that you could choose how you wanted it ( ie large garage high bed or low garage low bed ) rather than having the choice forced on you.
ips
506
4
Low profile
Have always camped, caravaned or had boats. Now in our second year with the motorhome.
RonW
Each to there own with regards to what layout works for them.
I have a garage with a wind up or down bed and agree that its not ideal for climbing out of in the middle of the night, however from my experience everything in caravans and boats etc is a compromise and for the extra storage space (including the scooter) its a small price to pay. Cant see how it can be deemed a "waste of space" I consider it to be a great use of space. As I say each to there own spose :thumb:
Ian
Maddie
245
14
Ashford, Middlesex
I would love to see pictures of that :Smile:
Bit difficult to take a picture but just imagine you are standing in the motorhome facing the bed, or in my case the bunks, you have a round shower on the right hand side and on the left the bathroom. If I stand inside the bathroom, I click a switch on the left side of the door and push that left side bit of the door out , so you block out the rest of the motorhome and it becomes a full width room. Try to have a look at the shows. I know that there are not many Frankia's here but you never know.
In the winter, I keep the door shut too when we drive as the living area becomes a bit smaller and so easier to heat. Has all kinds of advantages. ( shut the door when Roger takes a nap and won't be listening to his snoring :ROFLMAO:)
I see that you own an Adria and that is a great motorhome too. We had 4 of them ::bigsmile:.
Kind regards
Maddie
Maddie
245
14
Ashford, Middlesex
I made a mistake as I can see now that it isn't you who owns the Adria but it is Kontiki. :Blush:, sorry.
Maddie
ips
506
4
Low profile
Absolutely right...... before we got the scooter we had the bed not quite all the way down and there was still loads of headroom in the garage for storage of everything and the bed was low enough to be no problem at all. Now that we have the scooter (only had it a week and been away once so not in the routine yet) we plan to have the bed high (obviously) for transporting the scooter then drop it low when we get on site and the scooter is outside. If we dont need the scoot then we can drop the bed about halfway even with the scoot still in there ..... how adaptable is that ???? how can that NOT be deemed a good layout ???#
PS- With regards to fumes from the sccoot, I cant smell any as yet but will keep an eye (or rather a nose) on the situation.
bevo
218
4
north west
c class
garage
hi
mine has a garage in the back, it has a workbench a twin tub washing machine 2 folding bikes 3 3drawer plastic units in there all my beer (so i'm an alci) my freestanding awning
4 deck chairs my sattelite dish with tripod sun canopy, plus room for loads of tins of food and spuds (getting boring now)
also when i want to relax and watch tele (f1 or btcc) i go up on the bed and relax with a beer (got loads in the garage in a coolbox).
but that is what works for me and i think it's great
H
helenmccarthy
motorhome dog gate invention!!
Back on the topic of best inventions i've seen in motorhomes........
We were at the malvern motorhome show a couple of weeks ago - and we saw a new invention of a dog gate specific for motorhomes (and caravans!) - it neatly fits in the doorway, just slots in and out easy as anything! You don't have to fix it to anything and it folds flat for easy storage! They are hand made to the measurement of your doorway. I picked up a leaflet and this is their web address
K9gates - Home
if anyone has a dog and a motorhome or caravan, i strongly recommend you take a look at these - what a brilliant idea!:thumb:
Boo
633
4
Cornwall
A cls
9 years
The best i've seen so far with space utilisation in mind was the SkyDeck that Gold Rv's had Airstream Sky Deck | Quality Used Motor Homes from Gold RV
But personally I think the floor nightlights you can switch on all over my winnie is just a great idea and very useful staggering to the bathroom with one eye open in the middle of the night :thumb:
Boo
