What's The Best Way To Wire Up Hella Sockets?
Discussion in 'Tech/Mech General' started by Bellini, Jun 14, 2014.
  1. Bellini
    Bellini Funster
    Sep 3, 2013
    754
    794
    Crowthorne, Berkshire
    Dear assembled masses,
    I've just bought three Genuine Hella sockets for Udo to wire up in his garage, as below.
    http://www.ebay.co.uk/itm/Genuine-HELLA-Flush-Mount-DIN-Accessory-Socket-18A-Max-/120935212566
    I'm no electrician, so kindly ask how one would best wire these up?
    Is it a direct wire from the leisure batteries (Udo has two) or is it better coming from elsewhere?
    My instinct tells me to wire from the batteries with an inline fuse and maybe an inline switch per socket.
    What cable type do I need?
    Any advice, pointers and general guidance most welcome. :thumb:
    Si.
  2. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    768
    634
    Dumfries
    Din 12V
    Thanks for bringing that to my attention. I intend to fit a couple of these direct from my Solar, the auxiliary outlets. So with an inline fuse, both wires from the controller to suitable locations for running my Endless breeze fan particularly, and charging lappie and Kindles. I will leave the TV one as it has its' own socket(ciggy type, don't really like them).
  3. Bellini
    Bellini Funster
    Sep 3, 2013
    754
    794
    :thumb:
    Wiring them direct from the leisure batteries is fine, though?
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,172
    16,631
    Liverpool.
    Si, wire them directly to your shunt. That way you can see what each item is pulling and also the state of charge. You have a superior MH so stop fooling around wiring things to batteries :Rofl1:.
  5. Bellini
    Bellini Funster
    Sep 3, 2013
    754
    794
    :Rofl1:
    Ok, back to basics. What's a shunt? And where is it?
  6. Snowbird
    Apr 24, 2009
    10,172
    16,631
    Liverpool.
    Either in the garage where all the wiring is or under the bunk. More than likely in the garage. Take the cover off the power station and you will see a thick curly wire with positive and negative on it. All the wiring will go through this shunt to give you the display on your Votronic battery display. Whatever you fit 12 volt wise must go through that shunt.
  7. Bellini
    Bellini Funster
    Sep 3, 2013
    754
    794
    Dave, I'm assuming it's the light grey box on the right of the photo?
    [​IMG]
  8. Bellini
    Bellini Funster
    Sep 3, 2013
    754
    794
    Or any one of these?
    [​IMG]
