What's acceptable for damp test readings?
Discussion in 'Tech/Mech General' started by Ann&MikeMancs, Jul 27, 2016.
  1. Ann&MikeMancs
    Ann&MikeMancs Funster
    Oct 25, 2014
    105
    72
    Salford
    Just had damp test done (July) on our 'new to us' Carthago van. Would be grateful if anyone could help with what are 'acceptable'levels/readings.
    Muchas gracias!
    Ann & Mike
  2. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,414
    5,733
    St. Helens MERSEYSIDE
    Hi,I think as you are in the Salford area you may have a problem as its always raining there :).I have a damp meter /moisture meter with 2 prongs on and it reads 22/25 % if you put it on your hand so I wouldn't be too worried if you are having readings on that level also meters should be calibrated at regular intervals to maintain accuracy what sort of readings are you finding?
    • Funny Funny x 1
  3. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,583
    5,672
    Yr Wyddgrug
    From here
    0 – 15% No Cause for concern
    15-20% Require further investigation Consideration should be given to re-checking the area in three months with the average of all readings taken.
    20-30% Remedial work required, there may be early signs of water ingress or evidence of moisture. Resealing and internal work may be required; again, consideration should be given to re-checking the area in three months.
    >30% Structural damage is occurring, deterioration inevitable. a full strip down of the affected area is required.
    • Useful Useful x 2
    • Informative Informative x 1
  4. Ann&MikeMancs
    Oct 25, 2014
    105
    72
    Salford
    Haha. You got me on THAT one!
    It's been tested on OUR say so, at the dealers. When we take it back for more of the snagging list to be rectified,they say they'll test it again.
    We have a reading of 20 (X 3) going up by the door and an 18 at the top, all on the opening side, as opposed to the hinge side. There is a tall fridge by the entrance. One reading (the highest) of 23 is in the rear side 'wall' towards the roof.
    Just worried, as folks on here may recall we had an older van,where we found loads of similar issues just two weeks after the dealer warranty ran out! This van is 2012.
    Ann
