What would you do?
Discussion in 'Solar Power' started by treeman, Apr 11, 2012.
  1. treeman
    treeman Read Only Funster
    Nov 22, 2011
    112
    13
    poole
    Currently installing 215w panel on roof and connecting via 30A charge controller to LB. I store my MH many miles from my house and use at irregular intervals so looking to get some sort of trickle charging for starter battery.
    Options are:
    1. add some wiring to 215w panel as a fused jumper between + on LB and + on starter battery and remove fuse when using MH but replace when stored.
    2. Use a 5w panel I have lying around and make up a cigarette lighter cable to plug in when stored. The PV is diode protected so no battery drain. Handy as I could leave it on my car when away in MH!
    Any thoughts on which would work best?
  2. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,623
    7,497
    england
    just get b2b ctec charger from caktanks job done:thumb:less than £30:thumb:
  3. treeman
    Nov 22, 2011
    112
    13
    poole
    The only CTEK b2b charger I can find is the D250s which although I think will do the job is £207. I see a cak branded one on CAK website but no price I can see.
    I guess something like this would be a good solution if more costly.
  4. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,623
    7,497
    england
  5. treeman
    Nov 22, 2011
    112
    13
    poole
    Ah thanks, I'll get in touch with them - looks ideal.
    • Like Like x 1
