What size inverter.
Discussion in 'Motorhome Chat' started by plumbomb, Dec 11, 2014.
  1. plumbomb
    plumbomb Funster
    Oct 18, 2012
    203
    147
    Derbyshire
    HI, were looking at having a Pure Sine inverter fitted to our 2013 AT Apache634. We had a 85w solar panel fitted as a extra by AT & we have one leisure battery. the question is what size inverter,it will only be used for charging iphones,ipad & sometimes the wifes hairdryer.
  2. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    And that is where it all gets messy. Huge great inverter, huge great cables like tow ropes. Battery flat in no time.
    Whereas the phones etc only need a neat little inverter that will plug into a cigarre socket.
    • Like it Like it x 1
  3. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    1,022
    1,815
    Essex
    For phone / iPad charging we use one of these:
    http://www.amazon.co.uk/gp/product/B00GYNW1TA
    Hairdryer - forget it. Calcs based on the bottom end of the range, 1KVA @ 12V
    Cable size 16mm2 (calced on 3m run in free air)
    Autonomy using 85Ah battery to 50% discharge - about 3 minutes.
    Best advice - buy her a towel for Christmas :roflmto:
    • Like it Like it x 2
  4. scotjimland
    Jul 25, 2007
    28,994
    25,691
    Suffolk
    as they say.. ^^^^ (y)
  5. bungy
    bungy Funster
    Jan 24, 2010
    2,250
    4,143
    Welsh marches
    or just wire the inverter to the cab battery for the hair dryer use and have the engine running whilst its in use - and run the drier on low setting!! wife uses a 1200w one on the low setting and a 800w inverter copes nicely
  6. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,912
    23,658
    Narrfoook
    We have little 12v chargers for everything we use, from the fones to the kindles to the laptops to the iPads
    Absolutely no need for a battery killer at all :)
    And yes, get a bigger towel for hair LOL !!!
    just to give you an idea
    we have 300 watts of solar panels, 280aH of leisure battery and the only inverter I have is a wee little 300w jobby that to be honest I have NO idea what we would ever use it for except perhaps if we were off grid for a week plus and needed to recharge the eclectic cycle batteries
  7. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,943
    1,961
    Warwickshire
    If you cannot get suitable 12V charging adapters (e.g. Apple proprietary connectors) then a small 150W PSW inverter will be adequate. As others have said, a hairdryer is a completely different 'kettle of electric eels' - you cannot optimise both hair drying and small appliance charging.
    Here is my solution for low power needs:
    http://www.motorhomefun.co.uk/forum/resources/install-a-small-inverter.17/
  8. davejen
    davejen Funster
    Aug 21, 2008
    1,272
    722
    Kirkpatrick Fleming Dumfries
    Open a window and tell her to stick 'er 'ead out!
    Cheers, Dave(n):xlaugh:
  9. jemhorn
    jemhorn Funster
    Nov 13, 2013
    407
    377
    Bideford, Devon
  10. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,678
    5,879
    Guisborough
    How is the maths working here 1KVA is close enough to 1ooo watts, so with a few losses is about 100 amps for 3 minutes is 1/20 hour which I work out at 5ah, which a solar panel would put back in 2hrs sun willing of course.
    Or am I wrong, would not be the first time.
    After saying all that, two batteries would be better I run 2Kw inverter 0f 160 ah and use Microwave, Coffee machine and wife uses hair dryer and panels will put it all back in a couple of hours.
  11. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,224
    15,205
    Leeds the one up North
    I just love the opportunity :xlaugh:
    [​IMG]
    • Like it Like it x 6
  12. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,264
    17,930
    YO11 2BD
    since when did it only take 3 minutes for a woman to dry her hair ? :xeek:
  13. funflair
    Dec 11, 2013
    5,678
    5,879
    Guisborough
    Just took somebody else's numbers, nowt to do with me Guvnor.
  14. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    Yes, when it comes to BIG amps. That 100Ah battery will be specified at 10 hour rate, so 10 amps for 10 hours ( except we normally only discharge to 50% so 5 hours )
    But and this is a BIG BUT, go to 100A discharge and the numbers change dramatically. The chemicals cannot react fast enough and the battery becomes 25Ah.
    Rough figures and depends on battery construction with traction batteries dramatically better because they are designed to drive high loads and will have more lead plate area.
    You want heat, use gas. When the day comes and electric vehicles are viable then we can have a re-think.
  15. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    When she dries her pubic hair.
  16. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,082
    3,478
    Eastbourne East Sussex
    I must beg to differ. We have 2x125Ah batteries and 400w of solar with a 1500W (3000wPeak) inverter and run hairdryer 1200w , microwave 1200w and kettle 1000w without hookup in the summer. No probs. The inverter is close to the batteries with massive cables supplied with the inverter. Having 2 batteries effectively halves the current from each battery ie 1000w will draw about 50A from each battery. Fuses are 300a to the inverter and 150a between the batteries.
  17. funflair
    Dec 11, 2013
    5,678
    5,879
    Guisborough
    Even 50% is still around 50ah which in theory is 100amps @12 volts or 1Kw from 240 volt inverter for 30 minutes to flat not 3 minutes. Not that I would recommend that regime but happy to pull 100-150 amps off our old Gells for 5 minutes.
  18. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    Can't argue with any of that.
    For the benefit of others, how long can you run the microwave ?
  19. Techno
    Jul 28, 2010
    14,224
    15,205
    If you want a home from home you can't be unrealistic, you must man up or make do!
    [​IMG]
  20. sallylillian
    sallylillian Funster Life Member
    Oct 29, 2011
    1,072
    643
    Falmouth, Cornwall
    A key issue is type of battery if you are talking about these levels of amps being pulled. With big AC amp levels you really need AGM's which are comfortable with large amp draws and have acceptance levels of 2-3 times the total amps of the battery. The next is that whilst taking your bank down to 50% SOC before recharging is perfectly practical you are dramatically reducing the life of the bank compared to say 75%. If you are using your batteries in this way it is important to get a full charge, and that means getting to float for circa 12 hours or so on a regular basis.
