What model is my bog?
Discussion in 'Motorhome Chat' started by bigfoot, Aug 18, 2015.
  1. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,014
    5,325
    Wirral
    I have an 2010 A class Exsis i562 on a Tranny,the blade on the toilet has jammed. In the interest of expediency what model is it,as I want to buy a freshen up kit.Brief description,it has a swivel bowl and the tank has wheels with a trolley type bar to pull it (totally useless unless on a paved site!)
    Any idea which model bog I assume its a C200 but would like confirmation before I buy a kit.
    Thanks not crossing my legs-yet!
  2. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,503
    2,610
    UK / Spain
    Has yours got Orange wheels.
    http://www.ebay.co.uk/itm/CARAVAN-T...IES-4259262-/181827523511?hash=item2a55c3d3b7
    Ours has. :whistle: but I think our caravan has the C250 and the same seat that's 2009, but the camper 2012 is the C260 and has a more rounded seat although the cassette are the same.
    We had one jam and it was under pressure but managed to get the cassette out and you just turn the round top where the trap is and remove and put it back together. :eek: Bob.
    • Like it Like it x 1
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    There should be a (silver?) label on the cassette and/or in the locker giving the model number.
  4. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,433
    6,075
    St. Helens MERSEYSIDE
    Hello Bigfoot, Jacksons Leisure in Bromborough is the cheapest around for your new toilet kit.:)
    • Like it Like it x 2
  5. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,014
    5,325
    Wirral
    Thanks b&j,yes it does have orange wheels, can you clarify what you wrote-is it a repair? The old bench cassette we had in our old Hymer was far better.
    Thanks Mike for the info re Jacksons.
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    C200 does not have wheels or a tow handle.
  7. icantremember
    icantremember Funster
    Sep 2, 2010
    5,403
    7,502
    Nr Watton in Norfolk
    2010 with orange wheels & tow handle will be a C250 (I think the C260 was a little later).
    If the jam up is caused by excess pressure in the cassette then just loosen the cap on the emptying spout .... if you have a SOG fitted it will not be pressure causing your problem, but make sure the blade is fully closed.
    PS The C250 and C260 use the same cassette.
  8. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,014
    5,325
    Wirral
    Thanks for that,It is the blade that jams,I have emptied it and it seems to be the travel on the blade in that it doesn't open fully.
  9. bobandjanie
    Apr 28, 2008
    4,503
    2,610
    UK / Spain
    Hi, as said could just be under pressure, ours was and the other person in the camper :rolleyes: forced it and I had to take it apart and put it back together. :mad:
    To take the top out you just turn it, you will see two dots
    • Like it Like it x 3
  10. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,014
    5,325
    Wirral
    Thanks wildman,I'll give it a go.
  11. Ethle the wondervan
    Ethle the wondervan
    Mar 13, 2015
    204
    649
    Peak District
    If you look very very closely at the first picture you can see one grey pube and a bogey. :nerd:
    Make sure it all goes back together properly. It looks such a fearsome device I would be worried about losing a complete set of knackers if I coughed hard enough to set the trigger off! :whew:
    I wonder if it could be linked to an intruder alarm?
  12. Charlie
    Charlie Funster
    May 16, 2015
    2,544
    3,024
    I've seen that one before.. Made by Richard the third............
