What Is This? (1 Viewer)
Dec 5, 2013
317
249
Somerset
Newbie
Looks like something to do with the air suspension, someone who has the same setup will be along to explain I expect
May 31, 2015
11,628
44,287
Cornwall
Ducato PVC
Getting Better
It is air suspension look it up its a good thing.....
CWH
5,137
247,344
UK
WildAx PVC
From November 2013
Ah, now I've seen one of those at the dentist's ..... :whistle:
Minxy
32,623
66,460
E Yorks
Carthago Compactline
Definitely to do with rear air assistance suspension, have a shuftie underneat jus tinside both rear wehels and you'll see some black rubber fat tubes where the suspension stops should be.
autoswan
776
4,652
Swansea
coach built
i`m a newbie
It looks the same as on my Autotrail , I set mine to around 2.5bar, unscrew silver dust cap in centre open blue & red taps connect air line and pump up till you feel the difference driving and cornering etc... trial n error to get it how you like and load - weight affects it too. Once happy dont forget to close the taps and dust cap back on. Thats my take on it maybe others use it differently ? Jack.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
It's a newspaper detector - you appear to have a copy of the Guardian secreted somewhere about your motorhome.
If it was a copy of the Daily Mail the needle would be straining to exceed 7.
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
Identical to ours (But fitted a bit different) run our at 50psi to raise MH 2" so trailer is level, also use it to level MH on site (turn one tap open & release air, must remember to re-inflate) our instructions say to keep 5-7 psi in all the time
Candapack
711
2,639
Fife, Scotland
Since 2013
It's a bit concerning that whoever you bought it from, especially if it was a dealer, didn't explain it to you.
43,293
49,250
If, by any chance, its been connected in a nautical sense the red knob is the left air bag, blue is right.
If the van is a little lop sided open the tap corresponding to the lower side ONLY and inflate until level then close the valve.
dont EVER exceed the recommended max pressure or you could blow a bag.
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Look up airRide suspension looks to be their control in screw the cap ,you will need a small compressor ,we use to use the one that came with the car 12v plug in ,and as already stated open the required tap inflate to ? (3bar) close tap sorted good system
Mags52
Mags52
1,433
1,731
Melrose Scottish Borders
Hymer B774
Since 2010
Thanks folks. I don't think the dealer knew it was there.
It's too low at the moment then (just under 1)?? - will pump it up tomorrow.
Brilliant that it's on the van - it also came with a full Gaslow system and a 120w solar panel. Can't complain at that.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Yes left is red
Minxy
32,623
66,460
E Yorks
When we had it on a couple of our previous MHs we found that a bicycle pump could be used rather than have to cart a compressor around.
