What is involved in going down the Inverter route?
Discussion in 'Tech/Mech General' started by emmitdb, Apr 18, 2016.
  1. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,737
    1,611
    Cornwall
    Hi All,
    I know that there are some knowledgable types on here that have not only done the research but have actually performed the task.
    What is involved in, say, having an Inverter with the guts to do most reasonable things to allow one to go 'Off Line'. One that is plumbed in (to mix my power sources) to take over when the leccky from the tap is not available.
    I appreciate the need for sufficient battery banks and the solar to go with that but, how much is actually involved in providing the various conections to enable an on board Inverter to allow one to stay away from the mains.
    Is it a big job with many hours of work ( I couldn't envisage doing it myself) so Hrs. Means £'s.
    Any workings out on the back of a fag packet, gratefully received.
  2. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,578
    5,644
    West Sussex
    In the resources section there is an article by @Techno describing how to wire an inverter with auto mains switching. I did something similar myself and if did take a considerable time I wouldn't wanted to be paying someone to do it. The amount of labour involved with depends how easy it is to get as existing wiring and how the van has been wired. In my case I could only wire 2 of the 4 sockets to change over but I did add a couple of sockets in the garage for charging the bikes.
    • Thanks Thanks x 1
  3. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,616
    11,301
    Taunton Somerset
    For a good quality 2000 watt modified sine wave inverter fitted, adjacent to your batteries, with good quality Mega fuses installed on decent quality, correctly made battery cables, remote switched on and off, with automatic safety switching between incoming mains and inverted 220vac, wired with an RCD on the inverted output to all of your 13 amp sockets, you should be looking at £799 installed, with 13 amp sockets available when the inverter is switched on
    Of course, should you choose an installation Company that gives Funsters a discount (y) you could save 10% on that ;)
    • Like Like x 11
    • Thanks Thanks x 1
    • Informative Informative x 1
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    [​IMG]
    • Funny Funny x 4
    • Like Like x 2
  5. Techno
    Jul 28, 2010
    14,107
    14,921
    [​IMG]
    • Like Like x 2
  6. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,895
    5,157
    Guisborough
    I would think that Eddies offer is pretty good as there is a fair bit of messing about and Knowledge involved, you would have to be a die hard DIY'r to do it yourself. I would be careful to make sure that the Modified sine wave inverter will run everything you want as ours did'nt but there again ours was rubbish and Eddie did say "a good quality".
    Martin
  7. eddievanbitz
    Oct 4, 2007
    3,616
    11,301
    Taunton Somerset
    On our "installed" prices we take an average installation time, add up the SSP of the components and arrive at a "fitted" price
    In this case we calculate that it is two installers about four hours, with the longest bit establishing which sockets are on which wires ensuring that other 220VAC appliances such as charging units, water heaters, heating and fridges are not on the Inverted AC supply
  8. ianthebuilder
    ianthebuilder Funster
    Oct 24, 2015
    3,403
    8,652
    Helgas house
    You lost me at. Hi all !!!
    • Funny Funny x 8
  9. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,069
    492
    Any links to the mega fuses? Thanks.
  10. Techno
    Jul 28, 2010
    14,107
    14,921
    • Useful Useful x 1
  11. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,737
    1,611
    Cornwall
    I've actually seen the technology in the garage of Andy's van.
    Saw a similar setup once on an episode of Star Trek. Only on the TV that one wasn't as complex.
    Oh! and thanks for the fag packet.
    • Funny Funny x 3
  12. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,578
    5,644
    West Sussex
    Seems a very reasonable price when I remember the time it took to trace and rewire the mains in my van.
    • Like Like x 1
  13. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,759
    3,258
    Eastbourne East Sussex
    This is the type of fuse you need. I have a double fuse box but can't find one for sale anywhere now.
    Don't forget you will need a big fuse like this between the batteries as well, I only have two batteries with a 300A fuse one the inverter side and a 150A fuse between the two batteries.
    You can simplify the wiring for the automatic changeover by using a combined charger and inverter like this inexpensive one,http://www.ebay.co.uk/itm/2000w-400...837339?hash=item2ee33bb7db:g:mzwAAOSweW5VMmlq, and simply turn off your inbuilt charger. This will charge your batteries when you have mains and automatically switch to inverter if the mains fails or is not connected.
  14. colmorangie
    colmorangie Funster
    Nov 30, 2014
    77
    49
    Bonby, North Lincs
    I cut the wire 6" in from the EHU entry and put a single socket on the EHU side and a plug on the other end. Then ran a small extension from the inventor which is under the same seat to the socket.
    So if we're on EHU (rarely) you plug it in to that, if your not and you want 240v plug it in the inventor this would power up every thing however for the sake of the batteries I make sure the electric heater, water, fridge and charger are off or on gas so it only makes the microwave, and sockets live.
    I also purchased a socket night light and plugged it in to a obviouse socket so when it's switched on the light lights up. As on as the second time we used it we forgot to switch it off and the inventor flattened the battery.
    This was cheap and quick 1 hour work and the invertor from the old van o and 70p for the plug light thing...
    So am I missing something or am I set up in a dangerous way ?
    • Like Like x 1
