What is best..??????????
Discussion in 'Motorhome Chat' started by old-mo, Feb 3, 2012.
  1. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,918
    40,002
    We got to buy a new Electric Heater,,,, our little fan heater has given up the ghost...:cry:
    What is the most economical... A Fan Heater or an Oil filled Radiator. ??
    Thanks.. :thumb:
    Annoying thing is we have a Delongi Oil Filled Radiator at home which we occasionally put in the RV when it gets very cold back home, but didn`t bring it cos of space.. :Sad:
  2. scotjimland
    Jul 25, 2007
    28,939
    25,628
    Hi Mo ...
    watt for watt.. exactly the same.. and both are 100% efficient .. check the wattage before buying .. 1,000 watts ( 1kw) uses about 4.5amps .. (watts / voltage = amps )
    also bear in the mind the running cost if you are on 'pay per kwh' site .. can be expensive.
  3. old-mo
    Oct 16, 2008
    12,918
    40,002
    Morning Jim.... Thanks for that..
    As we have an Oil one at home I will probably go down the small Fan heater route again..
    Yes we are on pay as you use (Meter).... that`s why I was asking..
    Thanks mate.. :thumb:
  4. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,901
    13,932
    Norfolk
    Good morning Mo, I think a fan heater gives better circulation of heat :thumb:
  5. scotjimland
    Jul 25, 2007
    28,939
    25,628
    It would be cheaper to heat using LPG .. but I appreciate you have a tank and it's not always easy or convenient to fill it up in Spain.
    if you have a BBQ gas point you could plug in a Spanish bottle (with a bottle regulator) .. that's what I did.. also ran my fridge on LPG.. .. couldn't see a way of running the TV on gas tho ..:Laughing:
    • Like it Like it x 4
  6. old-mo
    Oct 16, 2008
    12,918
    40,002
    Thanks again Jim...
    Went to see (from when we lived here) an old neighbour and he said he would lend me a gas bottle...
    I have a bottle connector and an extenda stay fitted.. :thumb:
  7. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,262
    Gobowen near Oswestry !!
    A fan heater is using leccy all the time its running, whereas an oil filled jobby is thermostatic !:thumb:
  8. scotjimland
    Jul 25, 2007
    28,939
    25,628
    all sorted then :thumb:
    • Like it Like it x 1
  9. old-mo
    Oct 16, 2008
    12,918
    40,002
    The fan heater has worked well Steve... switching on an off OK, depending what thermostat setting we were using.. :thumb:
    See you shortly.. :BigGrin:
  10. 1Oll
    1Oll Read Only Funster
    Jan 12, 2010
    175
    86
    Cheshire
    Greenhouse Fan Heater
    I use a greenhouse fan heater, they can be used as a normal fan heaters. In the winter I just use the frost stat setting to just keep the temperature over 0 deg.
    Purchased from a charity stall at a car boot sale for £10(brand new in box). I've seen similar for sale at Aldi and Lidl occasionally. I presume that they are designed to be used in rougher conditions than a normal fan heater. I don't use the MHs heater unless we are on a trip, to save expensive repairs in the future.
    B.
  11. davidallan
    davidallan Funster
    Oct 22, 2007
    116
    37
    Leeds
    Which heater type???
    We have tried several types over recent winters even though we DO have 2 large Gaslow cylinders in place...for the onboard Ducted air system
    My take on this is that a FAN heater does do the job OK and circulates warmer air around- BUT my mind always seem to wander back to - How do you cool things down?? Blow on it!
    With different AMPs available on different sites especially in the EU we have finally settled for the Inexpensive 'Infra red' type instant heat heaters....There are Two versions generally available 2 Bars [ 400 + 400 watt] or 3 bars [400+400+400 watts] switchable Even for the larger version a £20 note should manage to buy one....certainley up here in Yorkshire !!:Smile:
    They do 'Glow' rather brightly though., and that may not suit everyone.....BUT seeing HEAT seems to do the trick for us....
    Hope this helps...David & Liz:thumb:
  12. tofo
    tofo Funster
    Oct 1, 2007
    6,669
    6,516
    Kirby cross further from londin
    Stating the obvious I know
    But no oil in a fan heater to leak in the van
  13. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,715
    23,108
    Narrfoook
    Mo, ours just died and it was the poxy power plug ( molded on one.. Cut it off and fitted a 'normal' one.. everything back to normal... Def worth a try for a few minutes work mate
  14. old-mo
    Oct 16, 2008
    12,918
    40,002
    Hi Mate... How is you.. ?
    Do you miss me.. ? :Wink::Rofl1:
    Ditched the old heater, and bought a new one, think the plug looked ok.. it wasn`t a moulded one... The light comes on but the fan didn`t go round.... so I think the fan was knackered.. :Blush:
