What electrical switch do I need?
Discussion in 'Tech/Mech General' started by FJmike, Feb 4, 2016.
  1. FJmike
    FJmike Funster
    Jul 17, 2014
    872
    905
    Swindon
    I have just bought a pair of Lumo led18 ceiling lights to replace the lights in my Pilot. The lights have 3 wires Black= ground
    Red= full light
    White= night light
    At the moment I have wired the feed to the red wire but I would like to have the option to switch either light from full to night. The feed comes from a switch by the door so I would like to put switches by both lights but I am not sure of the type of switch to buy or even if it's possible to switch the feed from one to the other. Any help would be appreciated.
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,898
    6,158
    Mansfield,Notts
    This may not be possible unless the led's are of the dimmable type
  3. DBK
    DBK Funster
    Jan 9, 2013
    9,218
    12,829
    Plympton, Devon
    If they are like ours they have two different types of bulb in them, one set bright, one dim - and blue coloured!
    They have a little rocker switch, one way gives the bright light, the other the dim.
    You just need a two way switch, which will have three terminals. The middle one (usually) you connect the common feed to and the other two terminals are connected to the bright/dim feed wires.
    Something like this: http://www.12voltplanet.co.uk/on-off-on-mini-rocker-switch-16-amps-at-12-volts.html
  4. xsparks
    xsparks Funster
    Mar 11, 2013
    237
    123
    Gillingham
    You should be able to obtain from maplins an automotive switch with a centre feed that switches to two positions I have used these in the past to make one supply do two jobs. someone beat me to the punch whilst typing.
  5. FJmike
    FJmike Funster
    Jul 17, 2014
    872
    905
    Swindon
    Thank you all for your quick response I would prefer to have white round switches as these would then match the switches that on nearby lights. Unfortunately after a quick search I can't find anything suitable?.
  6. FJmike
    FJmike Funster
    Jul 17, 2014
    872
    905
    Swindon
    • Like it Like it x 1
  7. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,920
    4,425
    Newbury , West Berkshire
    Bit difficult getting one in white Mike as all the car makers seem to think we all need black switches....the only thing I can think of is to carefully spray it with a humbrol enamel paint....on saying that some smartass on here will come up with a proper solution.. Roy
    • Useful Useful x 1
  8. FJmike
    FJmike Funster
    Jul 17, 2014
    872
    905
    Swindon
  9. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,920
    4,425
    Well whatever the outcome you cant go far wrong with the price of however would not be better to find a similar one that has centre off and one side to bright and other to dim .in other words centre infeed and the others outfeeds to lamps. ?
  10. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,390
    3,157
    Kendal, Cumbria
    I don't know what your existing switch looks like but another option is to fit an identical switch alongside it using one for bright & one for dim.
