what do fiamma awning numbers mean
Discussion in 'Motorhome Chat' started by Wildman, Mar 9, 2010.
  1. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    what do fiamma awning numbers mean, are they the length, width, different styles, will an awning from a 3mt fit a 4 mtr albeit with a 1 mtr gap will the end sheets fit all models etc. what does a 3 mtr awning weigh, what size is the packet?
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,335
    5,344
    East Sussex 01-580-881288
    The F numbers are the model types and no a 3m will not really fit a 4m. They are not actually that heavy. 4m weighs 26kg
    The side blockers fit most sizes.
    http://www.johnscrossshop.co.uk/products.php?product=Fiamma-F45ti-4.0m-Motorhome-Awning-
    Peter
  3. dellwood33
    dellwood33 Read Only Funster
    Apr 25, 2009
    3,449
    887
    Newcastle
    Why would a 3 metre awning not fit a 4 metre M/H ? or am I missing something here :Smile:
  4. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    Would a size 6 shoe fit a size 10 foot?
  5. gogocrosby
    gogocrosby Read Only Funster
    Apr 2, 2009
    84
    Morpeth, Northumberland
    Most simply, a 4 metre awning needs 4 metres of straight flat surface to mount it on.Most modern m/h's have a curved front.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,912
    17,579
    YO11 2BD
    it will...with a meter to spare:thumb:
    as above roger :thumb:
    the original question was "will a 3mtr awning fit a 4mtr van" :RollEyes::Smile:
    but i know what you mean :thumb:
  7. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    You will see privacy rooms advertized as2/3/4/5mtr with half sizes inbetween, 'medium' (up to 250cm high) or 'large' (up to 280cm high) this is the length of the side of the shaped panel nearest to the vehicle side. The size of medium or large will depend on where the awning roof frame is on the side of your vehicle down to the floor.
  8. clwyd
    clwyd Read Only Funster
    Jul 21, 2009
    29
    Ruthin, N. Wales
    Fiamma awning lengths
    Delwood's van looks about 5m long and is similar to my Renault Master Hitop LWB, with the roof (ie. mounting) part less than 4m.
    A 3.5 (F35) awning would just about fit at a push but 3m is ideal for mine - it cannot really overhang front or back and only needs to cover the doorway .... You need a few "flat" mounting points for the kit for your type of van. There is some mounting info. on the Fiamma site.
    The CaravanStor type is flexible and cheap for caravans but the mounting height on many vans is too high to reach for the regular fitting in each time used, so the fixed F type (or similar) is really needed.
    You can't fit a quart in a pint pot but you can the other way round. ... or a bun in a normal toaster - I've yesterday managed to find one wide enough to toast a teacake!!
    Derek
  9. scotjimland
    Jul 25, 2007
    28,934
    25,601
    Maybe I'm reading it wrong..
    Is Roger not asking, will a 3mt Awning canvas fit a 4mt Awning roller ?
    confusion reigns ..:Doh:
  10. pappajohn
    Aug 26, 2007
    29,912
    17,579
    YO11 2BD
    you could be right Jim, :thumb:
    and id say yes but it wont look right.
  11. dellwood33
    Apr 25, 2009
    3,449
    887
    Newcastle
    No but a size 10 shoe will fit a size 6 foot :RollEyes:
  12. dellwood33
    Apr 25, 2009
    3,449
    887
    Newcastle
    I think it's a 3 metre awning :RollEyes:
  13. dellwood33
    Apr 25, 2009
    3,449
    887
    Newcastle
    Hence my original confusion :Smile:
  14. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,605
    22,718
    Narrfoook
    At which point gentlemen, I think the only vaguely sane thing to say is Wibble
    It might not be sensible, it may not be helpful, but as least it will not cause any MORE confusion !! :BigGrin:
  15. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    let me rephrase my original question as I got it wrong and a lot of you are confused.
    One van has a 4 meter awning but no safari room, the second van has a 3 mtr Awning with safari room. can I use that 3 meter safari room on the 4 meter awning, I realise I would have a 1 meter gap in the front. Peter realised what I was getting at when he said the side blockers would fit most awnings. So apart from height everything else is ok as far as I am reading. Thank you ladies and gentlemen.:thumb::thumb:
  16. Spacerunner
    Apr 7, 2008
    609
    195
    Hampshire
    Yes you would have the metre gap plus the door, which could be permanently pegged in place.
    I should think it would be an easy job to have the front extended to fit the 4 metre one, so that your awning is completely enclosed. Quite important if its pitched in windy conditions. The last thing you want is a battle with a full awning because the wind has got under it.
