what did you fix today (1 Viewer)
calion
406
527
C class
since 2008
Trouble is, there will always be something that takes a lot of finding!
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
You probably know useful stuff then ................. unlike most of today's 'auto electricians' :):)
The main difference was that you repaired everything that broke down like dynamos, starters magdynos etc there were no replacement units readily available....but that said all components a d electrical systems on most cars was not complicated..
Simon
287
426
Ramsgate, Kent
Swift Kontiki 600
First year under our belt!
Replaced the front speakers in our '91 Ducato Swift Kontiki with some good quality speakers placed behind the seats. Ho yus! They'll drown out all the squeaks and rattles now!
GJH
29,450
38,827
None, now sold
2006 to 2022
I fixed the POIs on my new Garmin sat nav. When I loaded them the other day I forgot to set a parameter properly in the initial conversion from TomTom.
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
Jif (cif) and a toothbrush. Cleaned all the cab to body seams, the mastic joint, taken years off the ole gal. Used some good polish over the seams so should stop them blackening up too quickly ?? :)
Aug 18, 2014
23,742
133,210
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Repaired the side mosquito roller blind & top silver sreen roller.
Had to fabricate a new rear heater pipe for car that must have sprung a leak yesterday. Good job I always check water/oil etc; every time before I use anything.
Abacist
3,715
10,578
Devon
N & B Arto 88F Tag
since 2013
Cleaned the MH today and also clambered on the roof and scrubbed all of that clean using wooden boards to spread the weight. Raised all the roof lights and cleaned around the base of all of them and around the base of the lights themselves. Turned around the TV aerial as per advice from Techno100 and gave that a good clean and where it was parked.
Waiting for the arrival of the 2 new 125AH Hankook leisure batteries again as suggested by the master, Techno100! Just need to sort out the wiring loom in the leisure battery box which all seems to be very lightweight!
O
Old Soldier
Not exactly fixed but I have tried all sorts of proprietary brands to bring my black front bumper and rear wheel arch covings back to their original colour without much success. Today I reverted to my old army days and applied copious amounts of black shoe polish! They have really come up well, just remains to be seen how they weather in the next few days.....:happy:
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I appear to have fixed the leaky shower tap in my Carioca 656, fingers crossed.
I now have to update the W Europe map on my TomTom - the continent will probably have shifted a few metres by the time TomTom's snail-paced servers have coped with that.
Jul 24, 2009
4,326
104,076
South Yorkshire
Since 1999
Fitted new bulb holders to the reversing lights. Bought readily available units off ebay and modified them and then the housings to accept them.
Aug 18, 2014
23,742
133,210
Lorca,Murcia,Spain
Transit PVC
Dug out all cracks on front fachada.replastered with white cement + terrace wall. Cut all weeds out back & around olives, + front & 2 outside banks.Nothing on MH to
Dec 12, 2010
5,405
21,519
Cumbria
since 2011
Even after fitting a new lip seal, the casette has been leaking when you upend it to carry for emptying. After a bit of investigation, I decided to make a small spacer to increase the pressure of the blade against the lip seal. I had a look at pictures of a replacement blade and mine didn't look too worn and there was only a slight wear mark on the closing cam slide. Anyhoo, increased the length of the blade spigot by about 1.5 mm using a piece of white nylon I had in the garage and the jobs a good 'un !
Oct 15, 2012
10,178
57,288
Market Harborough
C Class Laika Ecovip 7R
Exchanged one of the 240v sockets for a electric / USB socket and fitted an extra arm rest from "Comfort arm rest system" to the driver seat then found why the converter never fitted one. The seat will now not turn round completely as the arm rest hits the steering wheel but I can live with that for the comfort while driving. :)
Jandc
61
130
lincolnshire
lowprofile
Since 2008
Not a fix really but we took out the air conditioning unit that was fitted when we bought the van and put back the Heki which the previous owner had left in the wardrobe
We were going to get the lovely guy who does our habitation service to do it but he was busy til July!!! We bravely decided on DIY, much easier than we thought it would be, we needed to rope in the neighbours though to help us lower the brute from the roof.
We now have 30 odd kilos of payload extra for our upcoming 6 week trip down to Italy. More room for wine and clothes!!!
Air con unit will be going on Ebay, would be great for someone with the payload to spare, heading for hotter climate and using sites for Electric hookup.
Feel quite proud of ourselves, used mastic strip from local dealer so hopefully no leaks either!!
Janis
Jandc
61
130
lincolnshire
lowprofile
Since 2008
Janis
Jan 19, 2013
132
109
Worcestershire
since 2010
Burstner Oil Change: Finally got round to doing the oil & filter change myself …… had to adapt a novel way of getting oil back into the engine though !
Not happy about the rust on the oil sump …. will wire brush and treat the rust today ?
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
Every day is Mercedes day for us, there's always things to do.
Latest includes the first new windows fitted after the outside cover sheets were fitted.
Broken Link Removed
Now changing oil and filters after taking of the intercooler pipe to change a messed-up gasket, new gasket on the right:
Broken Link Removed
Always something to do!
Peter
Feb 27, 2011
14,710
75,776
UK
Self Build
Just started building all the new furniture for my van. Not looking forward to ripping out all the old cupboards as I built them really well using mortice and tenon joins, pinned and glued with poly urethane glue so should be more a demolition job than precision work.
Mar 3, 2013
1,485
6,158
Poole
Have fun with that!!!! To be fair my sat nav was 4 years old when I did it but it took about 13 attempts and several online chats. Finally successful but now I can't put in post codes, thank goodness for longtitude and latitude co ordinates. I won't bother again .... :)
Bluestar
279
164
Brighton
Class
10 years.. On and Off
Just re fitted the radio Ariel that tried to commit suicide on the way to Peterborough next job untangle the dragon, (no not the misses) :whistle: that I brought at Peterborough and lasted a few hours in the wind :)
May 29, 2013
2,589
19,167
Tyneside
Chausson best of Flash 10
Several years now
Just fixed our dishwasher which stopped heating the water. Stripped all the side covers off, proved heater was OK, so looked at control circuit board. Found a poor soldered joint, remade it, jiggled each connector and put it back together. No-one was more surprised than me when it actually worked !!
And I didn't have any bits left over, which is a first for me !
Apr 27, 2008
11,842
14,067
Eastbourne East Sussex
Hymer low profile
Since 1972
Replaced the metal rail bit on the bottom shelf of the fridge door (Dometic) which had lost bits of its coating and was rusting in places. Replaced it with one bent up out of 4mm stainless steel rod, should last a bit longer. Cost £8.20 for the bit of stainless steel, I can see why they didn't use stainless steel in the first place, would eat into their profits.
Nov 4, 2011
5,920
38,676
Uk
Finally finished fitting new rear brake shoes and cylinder and front disc and pads, next on the list is a service, got filters and oils just need to do it. Then investigate doing the cam belt.
Jan 28, 2008
10,113
18,366
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
i think ive solved my long running radio problem radio was intermitently cutting out and finally traced it to the tweeter in the cab pillarloose
