cruiser
I did not fix .but got my van back on the road. Head gasket fixed head skimmed valves done water pump changed belts changed. So now I hope this van of mine will last another 28 years.
How's the hangover?Motorhome technicians in Nuneaton from Direct Motorhome Services Ltd
Yesterday Alan and his team worked all day on my Frankia and did a fantastic job, we then went out and got hammered
Awning was sticking now working fine.
Oil and filter changed.
Cambelt changed.
Waxoil seize sprayed under.
Bed gas struts changed.
x2 new roof lights installed.
12v socket installed in garage.
Wobbly reversing light fixed.
Battery top up.
... you've got the fan pointing the right way haven't you ....Fitted my new CBE fridge fans, since fitting, fridge temp has gone up from 3.5' to 10.1'
Bring on the new compressor fridges
Yes Mel, with all the heat there removing I'm at a loss?... you've got the fan pointing the right way haven't you ....
What happens if you turn them off ... does the temperature drop down again?Yes Mel, with all the heat there removing I'm at a loss?
Elusive little bar stewards, I finished up moving the back ones to the front helped with a touch of bluetac and put standard bump stop tape at the rear.today i thought i would look for the 2 of the missing little black rubber bits that the glass cover shuts on the sink but its so hot i had a beer instead maybe i will try next week maybe i wont
