What can I use..???
Discussion in 'Tech/Mech General' started by old-mo, Sep 2, 2013.
  1. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,762
    39,081
    We have two (2) very large Solar panels,, coupled to two (2) 180amp hr batterys (That look like they have come out of an electric milk float, Massive)..
    Also we have a "Waeco" Sin Power inverter. (Or should that be converter?:RollEyes:)
    My question what size wattage Kettle and Toaster can I run from this set up...
    Or should I be looking to buy lower wattage kettle & Toaster etc.. ?
    2nd.. Question.... the power points work of the inverter, "But" are they over ridden when on EHU.. and use the site electric...
    I`m :sorry2: if these questions sound as if I`m thick....... but I am when it comes to electrics.. :RollEyes::Sad:
    Thanks.
  2. Popeye
    Popeye Funster
    Sep 5, 2011
    7,806
    17,379
    New Forest
    ......and you ain't alone Old Mate...love the van Mo.......:thumb:
    • Like Like x 1
  3. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    There is no point in buying smaller toasters and kettles if the existing inverter is powerful enough to run them. You won't have any less water to boil just because you do it at half the rate. In fact, it will probably use a fraction less electricity to do it faster, as it has less time to lose energy to the surroundings.
    Of course, we don't know if the inverter is powerful enough as we don't know the rating of the inverter, the kettle or the toaster.
    As for how your inverter is wired up wrt the EHU, we can't answer that. Unless you have a default factory setup and someone has exactly the same model and can take a look at theirs...
  4. hilldweller
    Dec 5, 2008
    26,920
    25,766
    Macclesfield
    Can you see the INverter ? Can you find a label on it (using a mirror) ?
    Really you should re-think kettle and toaster. Gas is the best way to generate heat when not on hookup. Your gas tank(s) will hold probably 1000 times more energy than your batteries, which is why cars run on gas and not electricity.
    Is your next question "how do I empty the little cassette". A whole new world for you Mo. Welcome to the world of the mortals.
    • Like Like x 1
  5. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,266
    5,253
    East Sussex 01-580-881288
    Mo,
    Thats what dealers are for, they sold you the van, ask them and carry on until you get all the answers you need.
    Peter
    • Like Like x 4
  6. hilldweller
    Dec 5, 2008
    26,920
    25,766
    Macclesfield
    Says a man gnashing his teeth and muttering "Am I past it ? Have I lost my touch ? How the hell did I let that deal slip through my fingers ?"
    Don't be too hard on yourself Peter, he might be ancient but he don't half move fast when he gets the urge. Ask Judy !
    • Like Like x 3
  7. old-mo
    Oct 16, 2008
    12,762
    39,081
    I will ask, Peter...
    But in fairness to them I think they did explain on hand over,,,, but there is so much on here that it just fuddled my brain and gave me a headache...:RollEyes:
    • Like Like x 1
  8. teddybard
    teddybard Read Only Funster
    Aug 21, 2012
    7,610
    8,996
    warwickshire
    Hi Mo
    Its easier and to my mind better to run a Gas Kettle
    and toast using a double skillet or similar
    • Like Like x 1
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi Mo chances are the inverter will only power one socket--the others will be powered on HU
    Best way to find out is plug in and see what happens :BigGrin:
    IE no HU and see what works :thumb:
    HU and then see what works :thumb:
    you may well have to switch inverter on :Smile:
    try it all out on your drive :thumb:may well be worth taking a pen and pad :BigGrin:
    terry
    • Like Like x 1
  10. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,616
    11,301
    Taunton Somerset
    Congratulations on the new van it looks great :thumb:
    Inverters! If it is correctly fitted it should power all of your 13amp sockets but nothing else and there should be a transfer switch which will isolate the inverter when the motorhome is plugged into external mains.
    As for what you can run, the inverter will give you a wattage say 2000 watts
    If that is the case, you can look at a kettle and there will be specification plate (normally on the underside) Top Trade Tip empty the kettle before turning it upside down to check :Wink:
    Lets just assume the kettle is 2000W so yes you could, in theory use it on the inverter.
    However, a couple of pondering points. I always suggest that the rule of thumb workings out AC (mains) Watts to DC (battery) Amps is to divide by ten. So you would use 200 amps of battery power to boil your kettle. OK it won't take an hour to boil it but a couple of cups in the morning, midday, mid afternoon and one before bed and it all soon adds up.
    You should only use about 50% of your battery capacity on a regular basis, so you 180 amps to use. If you use up all of your "amps" for boiling water you'll have non left for things like lights and pumps.
    Hope that helps a bit
    Eddie
    • Like Like x 3
  11. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,266
    5,253
    When you look at all the members discounts available on Fun why bother with any other forum or supplier, you can even get a discount on bog rolls, the list is endless:Rofl1::Rofl1:
    10% discount to MotorhomeFun subscribers on
    KVH domes, Oyster satellite, Dometic, Waeco, Sterling, Solar, Strikeback & Growler Security Systems plus much, much,more
    Eddie Vanbitz
    Ash
    [​IMG]
    [​IMG]
    There are others as well
    and of course me
    Peter
    • Like Like x 2
  12. old-mo
    Oct 16, 2008
    12,762
    39,081
    And don't forget the most important trader, Peter.. =
    *OLD - MO`s* Maids Servicing Centre.... Satisfaction Guaranteed, or your money back...
    Mobile, and Many Happy Customers... :thumb:
    :Wink::Rofl1:
    • Like Like x 1
  13. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,681
    5,839
    Mansfield,Notts
    Dont worry about none of that crap Mo Just throw the switch on the dash that fires up the ole---------------------- oops Its a Euro:Doh::Rofl1::Rofl1::Rofl1:
    G
    • Like Like x 2
  14. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,695
    13,303
    Norfolk
    No Genny Geo :Eeek::Rofl1:
    • Like Like x 1
  15. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    listen carefully Mo....to make 'toast' you need a frying pan and some cooking oil.
    put a splash of oil in pan and place on gas hob, when hot put in a slice ofbread.
    when golden brown turn over and crisp second side.
    no need to butter as its full of oil anyway. :thumb:
    • Like Like x 1
  16. old-mo
    Oct 16, 2008
    12,762
    39,081
    Is That real Toast.. :Cool:
    I calls it Fried Bread... :Doh::BigGrin:
    • Like Like x 1
  17. pappajohn
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    real toast !...dont be daft Mo.
    its fried toast....taste awful with marmalade or jam, but lovely with a fried egg and ketchup.
    • Like Like x 1
  18. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi Mo are you telling us you paid all that money and the van has not got a oven or grill?:BigGrin:
    Terry
    • Like Like x 1
  19. old-mo
    Oct 16, 2008
    12,762
    39,081
    Strange as it may seem...
    "No"............. :cry:
    Got a pokey little oven, but no grill and No Microwave... :RollEyes::Blush:
  20. Chris
    Chris Funster Life Member
    May 5, 2010
    16,566
    35,250
    kent
    Hi Mo,
    In our Burstner we took a shelf out of one of the cupboards above the sink and fitted ( nice and snugly) a low wattage microwave.
    Might be worth looking at:thumb:
    • Like Like x 1
