What cable? (1 Viewer)
Patcherelli
56
25
Bedfordshire
Coach
Swift Sundance 630G
Planning my installation and I know the cable from panel to controller has to be the UV stuff but what cable should I use from controller to batteries?
Is it the same?
Thanks in advance
Sep 12, 2012
1,683
3,336
Wengen
A/S Broadway EL 2021
Since 2010
4mm Tri rated is what I use (y)
scotjimland
2,302
9,956
A Woosh bang
that depends on the cable length, voltage and max. current .. and also what % losses you are prepared to accept..
for example..
a 2mt run @ 14volts with a max load of 20amps with 3% loss would require .. 4mm2 ..
increase the cable run to 4mt and you need 10mm2 cable
use this calculator to size for yourself..
http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
Nov 6, 2013
1,414
3,157
S. Ayrshire
The usual
Since the beginning
Is it the same?
What size panel(s)?
What's the approx distance from the controller to the batteries ?
Patcherelli
Patcherelli
56
25
Bedfordshire
Coach
Swift Sundance 630G
I'm planning to add a second 110ah leisure battery and fitting a 100w panel. Distance from panel to controller around 3m controller to batteries 1.5m
Still very much at planning stage so all advice welcome.
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
The cable from the panel to the regulator is cheaper if you get a long MC4 and cut it in half then the cut ends pass through the roof gland and the other ends give you a male and female to plug into the panel. Its cheaper than buying two cables and cutting the ends off.
