What Broke on your MH this weekend (1 Viewer)
May 13, 2012
383
171
West Mids
Bailey Advance 6-2
since 2012
SO, things happen in threes....
This weekend :
1. As we were levelling up I pulled the Handbrake and it felt like it had come off in my hand, in fact it was just free moving because all tension was lost in the cable.
looking underneath I saw a bracket attached to either side of the van chassis where the handbrake outer tubes are captured to allow the tension (see photo). The off side bracket area where the tube mates had corroded and i had pulled the tube right through.
Luckily there was enough purchase on the top half of the bracket for me to use pliers and reform the shape enough to hold the tube.
Not sure how to proceed with it now, it seems to be working ok.
2. When opening the habitation door from outside the bottom of the handle "pinged" some bits flew past me (never to be found) and I couldn't open the door.
There is (was lol) a hinge arrangement by the look of it that allowed the action of opening the catch. We now have to push the bottom of the handle and pull the top to open the door :-(
3. When parking up back home today I turned of the ignition, removed the keys and OMG the engine carried on running. I put the keys back and tried off and on several times with no luck.
In the end I had to stall the engine, The stall seemed quite traumatic.
Does anyone know why an engine can keep running despite turning of ignition and removing keys? There was just the red battery light on when it was doing this.
Anyone else find that minor things like this are constantly happening when using the MH?
Ours is oldish (1997)
43,329
49,444
engine still running......
sounds like the fuel cutoff/stop soleniod on the fuel injector pump has jammed open
it is held open by 12v from the ignition switch and closes when the supply is removed...ign off.
removing and cleaning the plunger and seat may sort it but most likely needs replacing.
doubtful, but could also be a spurious power source caused be a short circuit somewhere in the wiring.
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
::bigsmile: I was doing a 3 point turn on a quiet road just outside a town in France when 2 things happened.
The gear knob came off in my hand and a spring flew past my ear-at the same time the volume of traffic increased dramatically :ROFLMAO:
I managed to park up and effect a repair by wrapping duct tape round the gear stick and hammering the knob (with spring) back in place.A month later we got home,having renewed the duct tape about once a week and had to pay £40 for a Fiat gear knob.:cry:
Mike
BigClick
May 13, 2012
383
171
West Mids
Bailey Advance 6-2
since 2012
Thanks PJ, I'l know what to look for now
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
I had a '92 544 about 6 years ago,bought in '94,the engine wouldn't cut off and,in my case it was a faulty contact in the ignition switch.
This week my Horizontal to vertical adjuster on my TV aerial broke,thank God for the radio!
43,329
49,444
when you find it, take it out and move the plunger in and out by hand then connect the wire, ign on and touch the soleniod body to the engine a few times.
if the plunger moves in and out freely that will confirm it works.
if no movement by hand its jammed open.
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
This weekend :
Blimy remind me not to let you near our Motorhome:Doh:
43,329
49,444
short circuit is easy to diagnose.
remove the wire from the soleniod and connect the meter, set to dc volts, to the wire and earth with ign off.
if you get a reading then theres a short somewhere or a fault in the ign switch.
maybe try that before removing the soleniod......its easier.
Terry
11,932
9,079
Lincolnshire
Can't remember ;)
This weekend :
NOTHING FELL OFF/or broke as usual :winky: but all the diesil disapeared after 350 mls ::bigsmile:
terry
Aug 5, 2012
125
99
Southampton
van conversion
since 1981 on and off
First time for a while on a site without EHU gas boiler worked fine for the first day then died,:Angry: I think it's an easy fix but can't get to the boiler without removing a lot of other stuff. back home now OK if a bit smelly:winky:. Will try fixing the boiler later.
TheBig1
17,630
43,275
handbrake will be an MOT fail and quite sensibly needs the bracket replacing due to corrosion
you need a replacement door handle assembly....try O'learys
sounds as PJ said like a fuel solenoid valve. they do stick when they get older/worn. I would say replace as it will fail again and cause the same problem where it would be dangerous to stall the engine
Youve not had the best of luck, but at least youre learning more about your van :thumb:
Stephen & Jeannie
4,174
3,265
Gobowen near Oswestry !!
Sold and bought a Caravan
9 years !!!!
1........Exhaust fell off !!:Doh:
2........Radio kept turning itself half on ( now replaced ! )
3........Leisure batteries registering 3 volts despite solar panel on line and nothing in the van switched on !
4.........:cry::cry::cry::cry::cry::cry::cry:
BigClick
May 13, 2012
383
171
West Mids
Bailey Advance 6-2
since 2012
Do you want to start a splinter group LOL. Maybe call it "The Popular Front for MH Unfortunates"
TheBig1
17,630
43,275
That's funny my diesel does that too
not as much as mine a few weeks back..... a high pressure diesel hose blew off the pump and emptied 1/4 tank in seconds whilst trying to restart. thought it had just stalled till we smelt the diesel and looked underneath
quickly fixed though with a new hose clip:thumb:
stcyr
1,765
1,160
Normandie
On & off, since 1966 - fulltime since 2005
Had a couple of occasions when the engine continued running when switched off (not on MH yet but 3 cars with the Lucas pump) - tiny rubber disc which seals the valve when ignition's switched off wears through leaving a small hole in the centre thus letting fuel continue flowing. Easy quick fix ... as long as you've got a spare rubber disc thingy :RollEyes: (although I did bodge once by carefully trimming a piece of bike inner tube which happened to be in the boot).
Mar 3, 2013
1,485
6,163
Poole
Wardrobe door catch, poor design. You have to tilt the handle inwards to open it and I suspect someone didn't do it and now the catch is loose so won't stay shut. Todd old electricians tape did the job. Nothing else this weekend although off to Belgium and France next week so anything could happen!!!
kaybee
23
214
Lincolnshire
C class
Since 2012
Arrived at Saltfleet on Friday. Was quite windy but very warm, Went to open the MH diner window, the wind twisted the window and broke the strut. Hey ho! Off to Devon with it tied up with an old shoelace. :Smile:
MHVirgins
3,889
3,158
South of Scotland
March 2011
Reading all these posts is a bit of a worry, we've had no problems with the Elddis since we bought it new, apart from someone reversing into the side of us.
However, now that we're trading it in, it's fingers crossed nothing goes wrong between now and the time we drive down south to change over in two weeks:pray:
Bill
BigClick
May 13, 2012
383
171
West Mids
Bailey Advance 6-2
since 2012
Bill
I'm sure you'll be ok. Remember Nick Ross from Crimewatch...
"Whatever happens, don't on our account have nightmares, do sleep well.'
:Smile::Smile:
DuxDeluxe
14,658
72,775
Planet Zog
A woosh bang van
since 2008
Scraped the rear corner on a fence post :Sad:
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
What Broke on your MH this weekend?
Nothing!
Wyn:ROFLMAO:
Nov 18, 2011
11,862
43,020
Planet Earth
A van
Over 25 year's
[FONT=&quot]We set off from saltfleet to finis our week end before setting off to rogers do the van started to overheat after abut twenty mils it is now using water and stemming like an old traction engine think the head gasket has gone got home ok but the old girl isn’t sounding to happy going to have a look tomorrow when she cools down:cry: [/FONT]
dna
Jan 17, 2010
673
4,084
Llandudno
AT Tribute 680 pvc
since 2009
1) The habitation water pump got slower and slower then stopped (not my fault but I do need to sort out a replacement. I emailed Adria in case they could tell me the correct pump to buy only to get an auto reply that they are closed for their annual holiday)
2) The fridge refused to light on gas (this one is my fault - ran out of Gas in deepest Brittany) :Blush::Blush::Blush: :Doh: :Doh: :Doh:. Note to self - when the indicator on a calor lite bottle is almost all red you are about to run out of gas and knowing the replacement is in the shed at home does not help
Aug 5, 2012
125
99
Southampton
van conversion
Nothing broke on our motorhome this weekend after all, but the muppets who sold it to me left the control cable for the gas boiler loose. Once I had my tools I found it straight away.:Smile: Shame I don't need it now:cry:
Apr 17, 2010
87
29
Basingstoke
hi top
17yrs
cor... im glad for my old '96 transit, the only thing that broke recently is the plastic hinges on the skylight cover.
