What are the tyre pressures of my Ford Herald MH?
Discussion in 'Compass Motorhomes' started by dickymac, Apr 18, 2009.
  1. dickymac
    dickymac Deleted User
    Hi,
    I have just bought my first MH, a Ford Herald Squire 98, but I don't know the tyre pressures. Can someone please put me right?
    Richard
  2. sinbad1
    sinbad1 Deleted User
    Check this site
    Better idea would be to find your axle weights and contact michlin withe your tyre size as i personally think the tyre manufacturers know best
    Regards
    You may like to read my query click here
  3. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,351
    1,439
    Suffolk
    I have never heard of your motorhome:Doh:, but a starting point would be to look at the max. load & pressure that is on the tyre wall, this would at least tell you the max. !!!:thumb::thumb:Then drop the pressures 'till at rides it's best.
    Thats a start anyway
    Nigel & Pamala
  4. derekfaeberwick
    derekfaeberwick Read Only Funster
    Dec 1, 2007
    1,131
    8
    Berwick
    Don't know for sure but assuming rear wheel drive,try 50 psi front and 60 psi rear until you find the official answer. Should see you O.K. for now.:thumb: p.s. nice looking vans those,enjoy.
  5. dickymac
    Thanks all!
    Never heard of mine then!?? Got a complex before I even get on the road :cry: :RollEyes:
    She does look good though! :BigGrin:
  6. Bulletguy
    Bulletguy Read Only Funster
    Feb 7, 2008
    2,051
    4
    Cheshire/Staffs
    Its a Ford Transit.
    Becks Motor Homes - 1999 HERALD SQUIRE 400 RL for sale
    My camper is a Transit and the pressures given (for diesel) are 50psi front 38psi rear. Loaded is same at front but 45psi rear.
    Dickymac......a worthwhile purchase if you don't have any manual with your van is simply to go and buy a Haynes Ford Transit manual for the year model of your van.
    All the mech tech spec and running gear is Ford Transit. The only part which isn't Ford is the plastic bit stuck on the back!
    One thing is guaranteed......you will be able to get parts anywhere, even in pretty remote european countries and never have to worry about getting them flown in from the other side of the globe. Plus, Ford stuff is dirt cheap and plentiful.
  7. derekfaeberwick
    Dec 1, 2007
    1,131
    8
    Berwick
    Maybe yours is fwd, I think rwd will be harder on rear axle.
  8. Bulletguy
    Feb 7, 2008
    2,051
    4
    Cheshire/Staffs
    Nope.....mine is a rwd Transit.
    Reason for the higher pressure at the front is because its a diesel engine.
  9. derekfaeberwick
    Dec 1, 2007
    1,131
    8
    Berwick
    Found a site with a 400 RL and the max weight is 3,300 kg. My rwd van is 3,500 kg with psi 51 front and 65 rear. Shouldn't think the Herald will be far from these figures. :Cool:
  10. dickymac
    Thanks all for your time and great advice!
    All the best!
    Richard
