What Are The Rules
Discussion in 'Motorhome Chat' started by swanseajack13, May 4, 2015.
  1. swanseajack13
    swanseajack13 Funster
    Aug 19, 2013
    494
    1,589
    Swansea
    is there a standard rule about the distance between m/h and m/h caravan and caravan m/h and caravan to avoid the spread of fire the caravan club rules are 6 meters between facing walls of the above that is a good rule but do private and council site have the same rules we had a caravan sited 55inches from use by the warden not happy about that he quoted some rule about a m/h can be moved if there was a fire what a tw*t help needed from my learned funsters lol ray
  2. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    6,259
    12,699
    Kettering
    Try going to a music festival or stay on an Aire. 2 or 3 feet is usual in those cases.
    • Like it Like it x 2
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,389
    18,078
    YO11 2BD
    No written or legally binding rule to my knowledge but common sense should Prevail.
  4. vwalan
    vwalan Funster
    Sep 23, 2008
    7,808
    4,089
    roche cornwall
    abroad they park that close if you both have swing out windows they would hit one another .
    dont use campsite is best option .
  5. Rolo
    Rolo Read Only Funster
    Feb 2, 2013
    35
    57
    Leyland
    Parked on an Aire in France last week stepped out of my vans habitation door right into my neighbour's lounge.... :LOL:
    • Like it Like it x 10
  6. vwalan
    vwalan Funster
    Sep 23, 2008
    7,808
    4,089
    roche cornwall
    can be a bit like boats moored up in a marina .
    takes some seeing just believe they park that close.
    on some aires they can almost double how many vans get on to what the books say.
  7. C200JK
    C200JK Read Only Funster
    Dec 27, 2014
    963
    3,174
    Ireland / London
    Had he a small trash and moaned about getting a kick in the nuts sometime in the 1930's-1940's ?!..... It was a concentration camp (CC) you were at, wasn't it ? ;)
  8. Puddleduck
    Puddleduck Funster Life Member
    Jan 15, 2014
    6,800
    14,646
    Scottish Borders
    Rules? There are rules?
  9. C200JK
    Dec 27, 2014
    963
    3,174
    Ireland / London
    You know....
    Those silly little things some bollox makes up..... and
    It gives us a kick breaking them just to get a reaction !
  10. Puddleduck
    Jan 15, 2014
    6,800
    14,646
    Scottish Borders
    The origin of the word "rule" is Latin and old French.... did both Latin and modern French at school but don't remember much. That's my excuse, it's all foreign to me :)
  11. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,468
    1,777
    Dover
    grey water drop on site????
  12. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    6,101
    9,987
    Lincs/Cambs border
    Sites licensed by Local Authorities, have to comply with a general set of rules dating back to legislation set out in 1960 (with amendments).
    Site Boundaries The boundaries of the site shall be clearly discernible on the ground by reference to, for example, fencing or otherwise defined to the satisfaction of Aberdeenshire Council, and in accordance with the approved plan. Spacing Subject to the variations in 2.2, the distance between any two units, or between a unit and a building, shall be not less than 6 metres. If there is a mixture of holiday caravans and touring caravans in the same area, the minimum spacing (including the spacing between any two holiday caravans) shall also be 6 metres. The point of measurement for the following variations of the spacings given in paragraph 3 is the exterior cladding of the unit, excluding the drawbar if any. All measurements are between the closest parts of the structures concerned. (a) (b) Porches may protrude 1 metre into the 6 metres space. If awnings are used, the distance between any part of the awning and an adjoining caravan/awning shall not be less than 3 metres. The distance between any unit and the site boundary shall be not less than 3 metres. Roads, Gateways and Footpaths The site shall be designed to provide adequate access for fire appliances. Wherever reasonable and practicable no caravan standing or toilet block shall be more than 90 metres from a site road. Common buildings and facilities shall be connected to the road by a footpath at least 0.75 metres wide and with a hard surface. Roads shall be at least 3.7 metres wide, with provision for passing places if the width of the road is less than 5.5 metres and subject to two-way traffic. This condition applies where a new site or extension is proposed and where alterations would allow the road layout to be improved. There shall be adequate turning space at the end of any cul-de-sacs. Roads shall be adequately surfaced and suitable to carry the vehicles for which they are intended. Gateways shall be a minimum of 3.1 metres wide and have a minimum height clearance of 3.7 metres. Roads shall have no overhead cables less than 4.5 metres above the ground. Roads and footpaths shall be suitably lit to allow residents to see their way about the site at night.
    3.10 Emergency vehicle routes within the site shall be kept clear of obstruction at all times. 3.11 The surface, gradient and width of roads and footpaths shall take account of the requirements of persons with disabilities. 3.12 There shall be adequate surface water drainage for roads, carriageways, and footpaths. 4. 4.1 4.2 5. 5.1 5.2 6. 6.1 6.2 6.3 6.4 Car Parking Up to two vehicles may be parked between adjoining units provided the doors to the units are not obstructed and this does not obstruct fire-fighting appliances. There shall always be 3 metres of clear space between a car belonging to one unit and any other unit. Site operators shall take particular care to ensure that other equipment, for example boats and trailers, does not encroach on the 3 metres of clear space. If particular equipment appears to the site owner to represent a potential fire hazard it shall not be stored between the caravan units. Limited parking shall be provided for any service vehicles or mobile shops which may use the site; or for caravans pulling on to while booking in or out of the site.
    All Local Authorities comply with these basic rules for camp sites.
    HTH,
    Jock.
    • Like it Like it x 12
  13. C200JK
    Dec 27, 2014
    963
    3,174
    Ireland / London
    That was becoming a very interesting read ..... but
    I suddenly gave up the will to live !
    Sensible rules... Nae..... Simple common sense is all that is required.
  14. C200JK
    Dec 27, 2014
    963
    3,174
    Ireland / London
    No,
    I'd wait till I was outside his office and stall it.....!
    "O look, my grey tap was open, silly me" !!
  15. Cobweb
    Cobweb
    Mar 25, 2014
    388
    350
    North Yorkshire
    If there are rules about distance between pitches they certainly do not apply in many campsites in Germany and Austria . A site we stayed in in the Black Forest was like a chicken hatchery ! It was not the only one ...I must say that I expected better from the Germans . In the end we decided that it was just as good to use the stellplatzes since many of them have hookup which is all we need most of the time .
  16. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,994
    Warwickshire
    I thought Porsche drivers took up any space they felt like using Jock!! :LOL:
  17. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,954
    The legal position is part of the Caravan Sites & Control of Development Act 1960.
    Under Section 5, local authorities may attach conditions to site licences which they issue and (ss6) the Minister may issue model standards which LAs must have regard to. The latest model standards date from 2008 and can be found Here and on many LA sites.
    S5, however, only applies to licensed sites. That means that it does not apply to any site established under an exemption in Schedule 1 so it does not apply to CLs/CSs, rallies, meets or THSs or to the likes of music festivals (or, as we found, camp sites at historical re-enactment events). In reality, though, sensible CL/CS owners and rally organisers follow the model as well.
    Spacing at aires in other countries is obviously not covered by UK legislation.
    • Like it Like it x 3
  18. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    • Like it Like it x 5
  19. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,155
    2,981
    Essex
    Having spoken to some Spanish campers as to why they park so close to their friends, their answer was, why wouldn't you???
    • Like it Like it x 4
  20. GeriatricWanderer
    GeriatricWanderer Funster
    Feb 1, 2015
    1,182
    4,270
    Soon to be bimbling down toward the Costa del Sol.
    Close parking can sometimes be an advantage. On one aire last year I was able to dip my bread in my neighbour's gravy without leaving my seat.
    • Like it Like it x 7
