Whale water pump inlet
Discussion in 'Motorhome Chat' started by Murphy, Jan 31, 2015.
  1. Murphy
    Murphy Funster
    Jan 31, 2015
    92
    52
    Mansfield
    hi all,
    I am thinking of fitting a whale water pump inlet to my 2007 Autoquest 130 and then having the pump sat in the water but all the time to up fill the on board water tank,
    Question is these come in either micro switch or pressurised ?
    Which was is required ?
    Anyone else done similar ?
  2. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,290
    3,093
    Kendal, Cumbria
    I have but the socket is permanently powered so that once the container is empty I simply unplug the pump. A mod for the future (that I've done before) is to use the drop in pump supply current once there's nothing to pump to switch it off. That way I can press a button indoors to turn it on then forget about it.
  3. Murphy
    Murphy Funster
    Jan 31, 2015
    92
    52
    Mansfield
    Thanks Tony,
    Did you utilise the micros witch model ?
  4. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,288
    3,732
    walthamstow east london
    if your just filling from a container its the microswitch type only runs while its poweredyou would never get pressure build up to work the pressure switch type as you will have an open end into the tank
  5. Murphy
    Murphy Funster
    Jan 31, 2015
    92
    52
    Mansfield
    Many thanks for the confirmation,
  6. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,985
    1,739
    Bungay Suffolk
    I just fitted an in-line household lighting switch..
  7. Murphy
    Murphy Funster
    Jan 31, 2015
    92
    52
    Mansfield
    How does that work ?
  8. jenny and mitch
    Sep 16, 2010
    1,985
    1,739
    Bungay Suffolk
    Sorry just re-read the OP.. I just followed Tonyidle and rather than unplugging, I just switch it off when container I am de-canting from is empty..:oops:
  9. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,575
    2,585
    Trowbridge
    My old caravan had a pressure switch. Turn the tap on and water starts to dribble, enough to trigger the switch and the pump comes on. It was the only pump it had common with many caravans. My camper has an in board with a submersible and a microswitch. the only thing with the pressure switch is it doesn't stop when the water runs out.. but then nor would a microswitch. I think if you are using it to pump water out of a container to fill an in board your best bet is to switch it on and off by hand.
