Whale water pump failure (2 Viewers)
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
We are at Oloron Sainte Marie hoping to head through today but no water.
The control panel says pump is on the pump fuse is OK, there is 12V at the pump but it's not running. Given our location where is the most likely place to get a replacement.
I fear Whale are unique to the UK, someone prove me wrong
Terry
11,929
9,044
Lincolnshire
Can't remember ;)
Hi have you pulled a pipe off the pump exit end to check if water is coming out ?...tried all taps?( you may have micro switches) Give pump a gentle tap.....you can replace the pump with any other pump if you cannot get a whale ( Surefow etc)
Terry
SomeoneElse
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
Hi, thanks for the reply, after a nice cooked breakfast, we have decided to carry on with our travels. When we are on sites in Spain we will have shower, and build up a supply of 5L water bottles for the trip home in two weeks time. The MH is a Bailey 625, the label is on the rear of the pump less than an inch from the wheel arch so impossible to read. I've peeled the label off so I can read it. The system is pressure operated so no micro switches. As I said before there is power to the pump it's not using it. The pump is a sealed unit so can't be repaired. I will give Whale a call tomorrow
cronkle
111
47
shropshire
c class
since1995
I hesitate to suggest this as the idea will most likely be poh-poohed but have you tried jolting the thing with a sharp blow. I usede to have to do this with the old SU fuel pumps in cars. I used to use a hammer. It was only ever a temporary fix (but did work for a few days) as the pumps were usually terminal at that point. Just thought you might find it more conveneint to do that rather than buying/filling plastic bottles.
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
If the pump gets hot after a few minutes of being switched on its seized up, if it doesn't its either the pressure switch built in that's failed or the windings have gone open circuit. Not a lot you can do except as suggested give it a tap when its powered up.
Nov 5, 2013
3,089
97,534
Shropshire
Carthago chic e-line
Since 2013
Posted by someone from Whale refering to FP 0814
I see from your recent posts that you have a question about the new Watermaster On Board Pump. This is indeed Whale's latest on board water pump and is straight forward to retro fit in place of a Smartflo.
The 'fully sealed' feature we refer to is actually that the electric motor being fully sealed inside the pump housing to protect the motor for long life. The pump is servicable.
We aim to make as many spare parts available to purchase from caravan retailers as possible. For this Watermaster On Board Pump, we offer a range of servicable parts:
  • Microswitch kit- Whale part: AK1317
  • Full head service kit - Whale part: AK1318
  • Strainer replacement- Whale part : AK1320
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
Looks like the micro switch can be accessed worth checking it may be possible to short it out and just use the pump switch as an emergency fix.
Lenny HB
53,315
149,507
On the coast in West Sussex
Hymer B678 DL
Have you checked you are getting 12V at the pump with the taps open, if not it could be a faulty pressure switch, if it's the switch it could be the electrical switch or the diaphragm faulty.
If that proves it is the pump should be able to replace it with any similar type of pump or for an emergency fix bodge in a cheap submersible pump.
MattR
4,097
38,542
Beds
Panel van
Years
Does the pump make any noise when turned on?
Have you tried sucking water through the taps to try and get a flow started?
Lenny HB
53,315
149,507
Hymer B678 DL
Forgot to mention if it turns our to be the pressure switch you could easily rig up an ordinary switch in parallel to get you home.
SomeoneElse
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
Thanks to Terry's suggestion of a gently tap on the pump I gave it a few "taps" with a bottle of my favourite Vouvray and it started pumping after much pumping which ended with some unusually slow strokes. We had water at the taps, but noticed the slow finish again. All seemed well but with it stopped the battery monitor was showing a discharge of 5Amps.
I have now worked out what happens the pump doesn't switch off and just stalls, over heats and some how trips.
We are now controlling it from the main control panel which gives us all fascilities we need until we get home.
Again many thanks for all the help, Fun is definitely the place for good advice.
Alistair33
1,079
3,258
North Yorkshire
Hymer
None
As an aside, looking at the water pump as an essential part of being self contained in a motorhome, is it practical to carry a spare and replace it yourself if it fails?
Lenny HB
53,315
149,507
Hymer B678 DL
Yes always carry a spare and to use it a couple of years ago in Greece. Hymers use a tandem submersible easy to change. If you have Sureflow they are quite expensive so in that case probably worth carrying a cheap submersible with a few bits to enable a jury rig in an emergency.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Indeed. Always carry two spares, a water pump and a serpentine belt for the engine. The spare pump I have carried for six years till it was used when we were away at Christmas when the pump was filling the locker and not the sink. :D
I'm not daft, I'm not silly, thought of this at day one. Can you imagine the grief, upon uttering the words "sorry darling, you can't have a shower or wash your hair, the water pump has gone phutttt and I do not have a spare". :)
