In 25 years of caravans and motorhomes I now have a very poor water system. It looks good elec/gas 750/1500w electric, 1250w gas and you can use both for quick recovery as it only contain 8.5 litres of water. My motorhome is Dec 15 and I have had problems since day one. The defect is that the system pressure drops and the pump kicks in to restore the pressure. The pressure relief valve is set at 3bar the system runs at 1.9bar. The relief valve constantly drips and this requires the pump to cut in. I have had a replacement relief valve and a replacement pump, no change whatsoever. The relief valve still drips. During the night the pump kicks in for less than a second which is s real pain in the bum!!! Whale suggested switch the pump off!! I can't believe it. The thermostat is fixed at 70 degrees C to eliminate bacteria, etc., I tried switching off the water heater at night but the pump still kicks in about every 5 minutes. None of the taps or toilet are leaking. Has anyone out there encountered this problem. Heater type Whale WH0802(B)
It's fine switching off pump at night then you forget and use loo, no water!! Not good in 2017.....
