Whale semi solid tube ...
Discussion in 'Top Tips & Tricks' started by Scotties, Apr 17, 2009.
  1. Scotties
    Scotties Funster Life Member
    Sep 23, 2008
    361
    167
    Norfolk
    Hi Guys,
    I know one of you will be able to tell me, can you use the Whale instant connection system with any other pipe such as the clear types.
    I'm trying to T or Y into one to put on a external shower and although they have the threaded type straight connectors I've not found any threaded T's in the local suppliers,
    Many thanks for your help, Richard:Smile:
  2. gazznsam
    gazznsam Read Only Funster
    May 15, 2009
    273
    Eastwood, Notts
    you have to use the semi rigid pipe with the push fit connectors, as they clamp onto the pipe when you push them home, and if the pipe isnt rigid enough, it'll pop out.
    you can get adaptors to go from the flexiable pipe to the semi rigid stuff, but for your application this would be a bit overkill (4 adaptors to take hot and cold to semi rigid pipe, then the T pieces, then to the outside shower i presume in semi rigid.... but if it needs to be the flexi stuff, then 2 more adaptors, upto 18 different leak points.
    if you can find a hydraulic hose shop in your town, they will be able to come up with what you need, i use a hydraulic hose place a lot when i fitted the wet central heating to my motorhome, use that pex 15mm barrier pipe and push fit connectors, but to connect to the eberspacher i needed to go to car heater hose and clamp fittings, and had to go to threaded fittings for the calorifier connections and so on.
  3. Motomuz
    Motomuz Read Only Funster
    Aug 26, 2008
    14
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,423
    East Sussex 01-580-881288
    You mean this one>> [​IMG]
    Peter
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,115
    17,785
    YO11 2BD
    for the domestic plumbing market (Hep2o) you can get sleeves that fit inside the pipe and makes it more rigid and retains the round section where it fits in the pushfit bit.
    probably get 'em in the size needed.
