Whale pumps
Discussion in 'Tech/Mech General' started by lugnutt, Sep 4, 2013.
  1. lugnutt
    lugnutt Funster Life Member
    Sep 9, 2007
    1,183
    455
    wednesbury.westmidlands
    i have taken out a whale pump up0814 30 psi and flow rate of 2.2 these are no longer available so i bought a universal uf0812 only to find it is only 15 psi flow rate the same . will this be ok? anyone had this problem?
  2. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,552
    7,834
    Put it on and see what happens.. Guess it can only pump a little slower...
  3. lugnutt
    Sep 9, 2007
    1,183
    455
    it is bigger and seems more robust than the old one. the cut out pressure is 15 psi/1bar does that mean the system operates at less pressure is that a good thing?
  4. lugnutt
    Sep 9, 2007
    1,183
    455
    the flow rate is the same 2.2/8 lts per min
  5. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    It will only make a difference to the shower. If it was anaemic to start with, you might prefer a higher pressure.
    The normal taps won't notice. Although if you normally get bangs when you turn off the taps, this will improve.
  6. wasp
    wasp Funster
    Dec 21, 2008
    2,730
    1,066
    Mansfield
    If you got the flow rate the pressure doesn`t matter that much, the shower should be the same
