We're off to France in a couple of weeks - what connectors do we need? (1 Viewer)
Southdowners
3,358
25,320
West Sussex
Concorde Charisma
Since May 2015
We've decided against Scotland this year because of the weather and decided to chase the sun and go to the south of France.
Although we're quite familiar driving in France (we owned a chalet in Morzine) we've never been in the motorhome before. Can anyone tell us what we need for gas and electric please? Do we have to buy different gas bottles entirely or are connectors available to make our existing bottles compatible? Same question with electric. If connectors are needed, where do you buy them?
Jan 8, 2013
8,490
11,526
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
A French plug to 16a cable adaptor easily available at camping shops might be useful.
You can get free bottles from Supermarket Chains (we use Super U) in France, you need only pay for the gas. You will then need to buy a French regulator from a Brick o Mat or some such. It is then simply a matter of finding the nearest Super U (there are hundreds) when you need a refill.
We have a tee piece with a Calor regulator and a French one piped together, we simply swap between them
DBK
18,009
48,006
Plympton, Devon
PVC, Murvi Morocco
Nov 13, 2012
440
438
Somerset
coachbuilt
since 2000
Reverse polarity plugs are handy as some sites are wired up in reverse also a plug in reverse polarity tester
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
Keep reading about this reverse polarity malarkey. What is it and how does the appliance know which way the elastic trickery is going? If the the appliance does not know why do I need to know?
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Reverse polarity is when the live and neutral are reversed. It used to be a lot more common years ago and we always carried a plug in socket tester and screwdriver. After a while, I made up a reversed polarity 16a hook up plug and could swap them over if necessary. So on a U.K. circuit, the live is fused. France don't do fused plugs, they have double pole circuit breakers ( and a good thing too, the French plugs, sockets and switches are crap)
On my fuse box, I have a light that tells me if the polarity is reversed. If it is, and you have a U.K. plug plugged into the van ( usually older vans with no circuit breakers) and the fuse blows, the live feed is still there.
Probably.
I would be more worried about having the right size tap adapters. French taps seem to come in more sizes than U.K. taps. Good news is, many supermarkets and diy stores sell these adapters. Buy two of each because you WILL leave one on a tap somewhere. Mine is at an aire in Mutigny!
R
Robert Clark
This is the sort of thing you want for the leccy. http://www.johnscross.co.uk/caravan...Fc2uLcF148GZbq2ysV-D3L6ZfWUgdNhpHUhoCir7w_wcB
You will need them at some places at others the normal one you use in the UK will be needed. The adaptor will work in other countries too. Nearly half the places we stayed at in Spain over 8 weeks needed the two pin plug.
Johns cross add extra for postage and packing - also I just noticed that their returns policy does not comply with current consumer legislation
I'd suggest getting one off eBay, with free delivery
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Since 2012
Don't forget some tap/hose connectors for fresh water (if you intend to fill up your on-board tank that is).
