Well done Dave Newell
Discussion in 'Tech/Mech General' started by WynandJean, Mar 3, 2016.
  1. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,694
    1,492
    West Midlands
    Last year my Omnistep stopped going in. I could get it to go out and could retract it using the dashboard button but the button over the step would only work one way. I tried checking the step itself and could find nothing obvious so ended up being sold a replacement switch by a local supplier. This used spade fitting to connect which meant cutting the original connector off the wiring and soldering the spade fittings to the end. Not only did this not solve the problem it meant the spade fittings were too long to fit in the space available. I tried another switch marketed as 'the replacement for all previous switches'. This proved no better. I was able to make a temporary solution by attaching a clip which when attached worked in the 'out' direction and when disconnected let it 'in'. This at least proved that the step itself is OK.
    I have a friend who restores classic vehicles. He took a look and said that the wiring was correct and could not understand why it would not work.
    In the end I had to take it in to have it sorted out once and for all. I took it in to @dave newell lvs this morning. I asked if it would be possible to reinstall the original switch. He pointed out, however, that since I had cut it off its wiring he would not know which wire went where.
    This afternoon I got a call to collect the van. All done.
    He said he was not sure whether the original switch was pushed upwards for 'in' or 'out'.
    Let me tell you Dave it is just as the original. Works perfectly and it's fine.
    Thank you once again and if anyone is in doubt about visiting you I can thoroughly recommend your work.
    Wyn
    • Like it Like it x 15
    • Useful Useful x 2
    • Informative Informative x 1
  2. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,625
    3,457
    Telford, Shropshire
    Thank you very much for a lovely write up, its good to know we hit the mark and have satisfied customers.
    D.
    • Like it Like it x 14
  3. MikeD
    MikeD Funster
    Dec 21, 2011
    2,203
    1,922
    London
    Top people - Dave and Jackie (y):)
    • Like it Like it x 2
  4. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,694
    1,492
    West Midlands
    Every time I have brought the van to you I have been more than satisfied with the outcome and I suspect that others might have said, "sorry mate we can't do that" but you have always come up trumps and gone out of your way to overcome the problem. Well done and many thanks to you and Jackie
