Weird lighting problem
Discussion in 'Tech/Mech General' started by tuglet, Apr 2, 2016.
  1. tuglet
    tuglet
    May 24, 2015
    5
    Stirling
    Hi all, after some advice from the experienced electricians. On our 2012 plate Rollerteam TLine 700 on a fiat Ducato we have this unusual external lighting issue. When I turn lights on all external lights illuminate then after about 5 seconds the following lights go off. Rear left, Rear upper right led marker, rear left hand side Amber marker strip and front left side light bulb. When I brake rear left brake works perfectly. Whether lights on or off. On the internet I read a suggestion from other people's questions that Fiat Ducato monitors light circuits and will de-energise a circuit if it detects something slightly strange on any lighting circuit, sometimes accompanied by a dash lighting warning. I don't get any dash warning lights. Others have cleared lighting faults by disconnecting both batteries, presumably to reenergise the ECU which is controlling the lighting circuits. I have tried this with no success. Embarrassed to say I was an aircraft electrician to trade in the past but without wiring diagrams I am completely foxed by our issue. Anyone any ideas - all help gratefully accepted. TIA.
  2. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,373
    10,291
    Lorca,Murcia,Spain
    Hi & welcome. Sounds a bit like an earth fault to me.
    • Like it Like it x 1
  3. scotjimland
    Jul 25, 2007
    28,938
    25,625
    agree with gus-lopez
    most lighting faults , especially weird ones, are bad earth connections , rusty , corroded or broken .. or water in the lamp holder
    marker lights are favourite .. remove and inspect, starting at the top front
  4. andy63
    andy63 Funster
    Jan 19, 2014
    2,226
    8,524
    south shields
    It does sound classic earth fault,but the fact that they all come on and work normally for a short period may mean it's a electronic control fault... If a detectable fault was causing that you would expect a warning light to come on...
    That's my thoughts... but hope you get it sorted and let us know what it was....
    Andy
  5. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    Could be a heat build up earthing problem? When the bulb heats up the earth breaks down.
  6. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,487
    6,481
    West Sussex
    Sounds like an earth problem but your van has a canbus system so could be another electrical fault that is nothing to do with the lighting circuits.
    • Informative Informative x 1
  7. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,752
    10,172
    this is actually pretty common but can be hard to fault find. the side light circuit is drawing too much current so the ecu protects the circuit by turning off.
    bad connection on front side light
    bad connection on connector under the cab by the loom extension joint
    bad connection at marker lights
    bad connection on rear light cluster
    a bulb starting to fail so high resstance
    a bad earth at any of the affected lights
    sometimes you find it first time sometimes it takes hours
    • Useful Useful x 1
  8. tuglet
    tuglet
    May 24, 2015
    5
    Stirling
    Thanks all for some sound advice, i will try changing other filaments one at a time - already changed out rear left as this was the first we noticed. Need to get van out of driveway to work on it so probably next weekend. Will post if I find a solution.
    • Thanks Thanks x 1
  9. tuglet
    tuglet
    May 24, 2015
    5
    Stirling
    OK folks the knowledgeable amongst you were right. When I managed to investigate the problem this morning the side lower position(?) light was the culprit. The filament holder within the unit was full of water and there was the obvious short. Guess the body computer was detecting the short and deenergising that circuit of lights for safety. All cleaned up dried out WD40 applied all reassembled and lighting problem solved. At least I know for next time. Phew one happy Moho owner again and roll on last week in April when we head down to Cornwall for a week!!
