Webasto fault code 10 overheating.
Discussion in 'Tech/Mech General' started by irnbru, Nov 2, 2014.
  1. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,816
    10,984
    Glasgow
    As we set off on Thurs I put the webasto heating on but around 15 min later I heard the fan cooling down noise come on. When I stopped 2hrs later I noticed the fault knob flashing 10 times.
    Used the heating yesterday for about an hr and half and it seemed fine. Turned it on today again and after an hr its cut out again with the same 10 flash overheating code.
    Can anyone tell me what I should be trying to do to fix this please.
  2. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,506
    3,711
    Lost in La Mancha, Spain
    10X Flashes (F 10)
    Overheating
    Air flow
    Wiring
    Defective temp. limiter
    Switch heater off and back on (see air flow)
    Motor/fan obstruction, heating air flow blocked
    Damaged or corroded wiring, open or short circuit
    Replace temperature limiter
    There is the list above. I would check all the air flow areas incase something is blocking them.
    • Like Like x 1
  3. irnbru
    Jun 27, 2013
    5,816
    10,984
    Glasgow
    Thanks John. Ive had a look at where the big thick airflow pipe is under the dinette table and it looks like the pipe air comes from a vent at the bottom of the table so im wondering if this is the airflow in and if its maybe being caused by the dog lying there or is this just rubbish?
  4. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,506
    3,711
    Also check under MH around the exhaust exit incase mud has partly blocked it.
    • Like Like x 1
  5. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    Have you checked the return air duct at the unit. The rubber pipe sits on a very small flange. Mine fell off and the unit overheated, presumably because the return air stat thought the heater wasn't doing its job properly and kept it running.
  6. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,939
    West Norfolk
    Yes! If the dog is obstructing the the heater air inlet duct, the heater will overheat!!
    • Like Like x 1
  7. irnbru
    Jun 27, 2013
    5,816
    10,984
    Glasgow
    Thanks.
    We moved the dog and it worked again. Now looking to make a wee guard to put over the vent.
    It just shows how easily lessons can be learned and how much the £10 membership fee can save you on repair bills with the invaluable information received on here.:)
    • Like Like x 1
