We think the turbo has gone bust
Discussion in 'Tech/Mech General' started by Scattycat, Aug 2, 2016.
  1. Scattycat
    Scattycat Funster
    Jan 3, 2013
    844
    1,184
    Mayenne, France
    Any ideas what the cost to supply and fit a new/re-con turbo would be for a 2008 Citroen Jumper/Jumpy 2.2 is likely to be?
    Just set off on our trip to Italy to meet up with some of the family, 10 km down the road the felt like it was mis-fireing and came to a stop. Started it and turned around to go back to our local garage and after a couple of km the engine started racing out of control. I pulled into a farm entrance, turned off the engine, counted to 10, ('cause it seemed like a good idea), tried to start again but nothing.
    Breakdown truck arrived and towed us to the local garage but, this is France, they were shut on Monday.
    Now it's August and most things are closed down it could be a couple of weeks before we are up and running again.
  2. Figaro
    Figaro Funster
    Feb 22, 2011
    1,109
    848
    Newcastle under Lyme Staffordshire
    Sorry to hear of your problems, can't help with the tech stuff but hope your sorted soon
  3. seanoo
    seanoo Funster
    Nov 14, 2009
    374
    228
    normandy
    hi mike , i know its not the same engine but i had a similar problem with my sprinter , engine revving all over the place and no power. turned out it was the turbo actuator valve which uses a vacuum to control the turbo. £125 and half hour and good as new! hope yours is something similar
    • Like it Like it x 1
  4. Lot lover
    Lot lover Funster
    May 13, 2016
    572
    505
    Lot, France
    Scattycat, as you know French garages are not inclined to fit parts that they have not supplied so you can't even source one on the interweb and save a few hundred €.
    But look on the bright side, it happened 10km from home and not on the M20 2 weeks ago.
    Bonne chance anyway
  5. chaser
    chaser Funster
    Feb 16, 2013
    7,993
    9,050
    uttoxeter
    Doesn't sound like turbo to me , did the breakdown man say it was.
  6. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,661
    5,860
    Guisborough
    If it was racing out of control because of a turbo oil seal failure and the Diesel engine was running on engine oil it should have been accompanied by lots of light coloured smoke and a very very oily exhaust.
    Martin
    • Informative Informative x 1
  7. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,293
    3,094
    Kendal, Cumbria
    Under those circumstances it would not have been possible to stop it by turning off at the key.
    • Like it Like it x 2
  8. Scattycat
    Scattycat Funster
    Jan 3, 2013
    844
    1,184
    Mayenne, France
    Yep, that's about the size of it regarding the smoke but I didn't check the exhaust.
    After I turned the engine off I left it a couple of minutes and tried to re-start it but the starter wouldn't turn the engine over but it would an hour or so later
  9. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    Dont like the sound of THAT!! Could be a cylinder is hydraulicing, fuel, oil or worse water entering the cylinder in such amounts that it stops the piston reaching TDC.
  10. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    Er, daft question, but you haven't by pure chance filled up with the wrong fuel?? o_O
  11. Scattycat
    Scattycat Funster
    Jan 3, 2013
    844
    1,184
    Mayenne, France
    Only if it was crappy deisel
  12. Derbyshire wanderer
    Derbyshire wanderer Funster Life Member
    Mar 30, 2014
    568
    922
    Derbyshire
    Did you fill up at all just before it became faulty? If so, a sample needs taking before fitting anything.
    It has been known more than once for a garage to end up with the wrong fuel in their tank.
  13. funflair
    Dec 11, 2013
    5,661
    5,860
    Guisborough
    Turning the key off stops the fuel but you are right it could take a little while to stop running on oil, happened to a friend of ours and it did stop but reluctantly.
    Martin
  14. chaser
    chaser Funster
    Feb 16, 2013
    7,993
    9,050
    uttoxeter
    You may laugh , but I always make sure the nozzle I am useing is connected to the proper pump, it would be quite easy for some wag to put the wrong nozzle in the wrong pump, think about it(y):(
  15. Gromett
    Gromett Funster
    Feb 27, 2011
    8,244
    15,357
    UK
    Any updates in this? Did you get it sorted ok?
