watre pump air heater questions (1 Viewer)
mal6186
13
have just bough 1993 autosleeper trident on vw t4. Lovely and all seems functioning:
it has two black square air vents near floor - when carver 1600(?) air heater is on air only comes out of top one - is this right? when on fan (fresh air) mode it is the same but air is warm (heated) and doesn't feel like fresh air.
water pump - tank is full, water pump is on/whirring but no water comes out of tap wherever it is turned - any more likely faults/solutions people think i should check first?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
As Peter say's have someone with you
That way you will both get wet:ROFLMAO::ROFLMAO:
Geo
M
mal6186
13
took inlet and outlet pipes off - should i be able to feel suction or blowing when running it 'dry' because I cant. As i said pump is running, filter is clean. Took it apart and couldn't see any splits or leaks etc. there is small allen key adjustment at end - some sort of switch? Any advice appreciated.
43,323
49,434
centrifugal pump (whale type) it could be the impeller has jammed.
throw-away item i think.
diaphram pump (fiamma, shurflo) it could be a valve is jammed or has dirt in it or the diaphram has split.
spares are readily available
reconnect the inlet and fit a temperary hose to the outlet....turn on pump and suck on the temp pipe....be ready for a large gobfull of water and have somewhere to put the hose if it starts to pump, until you can turn it off.
M
mal6186
13
its a shurflo pump - seen new ones advertised near me in bradford for £40 so might just get new - hardly aseems worth the hassle of replacing bits for that. Diaphragm doesn't look split but obviously something up with it.
