Water tap locations (1 Viewer)
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Is there a list of water tap points anywhere? Arrived up near Inverbeg on Fri night only to find we had an airlock and used all our water trying to clear it. Had to drive 9 miles or so to Balloch on Saturday morning, ended up paying a campsite £3 for water. A water tap location points would be handy :)
scotjimland
2,309
9,979
A Woosh bang
never seen one..
places to get water:
Garages, service areas,
Garden centers
Church yards
Cemeteries
Public toilets.. some have outside taps
Car parks
Marinas
Boat yards
Harbours
etc
scotjimland
2,309
9,979
A Woosh bang
Its not really that long... is it?
if you are off site camping you need to carry plenty of hose, I used to carry 3 x 20 mt rolls.. and a watering can .. never get stuck ..
I would suggest a minimum of 20 mts .. plus a good selection of tap adapters including the rubber push on type .. in two sizes
Mr Mousy
619
3,105
Llanelli
Hymer S840
First moho 11/2013, second 11/2014 current from 09/2019.
The wildcamping web site has a poi file you can download for your satnav (if you subscribe) of lots of tap locations. I guess they will be the type of locations ScotJimland has listed.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I find carrying an Aquaroll is better than hose (or at least the ex-tugger in me does). Think of it as an infinite length of hose. I made a simple device to lock it below a cycle carrier so it isn't intruding on somewhere useful for other things.
scotjimland
2,309
9,979
A Woosh bang
What size connector is normally used on sites regards
as said they do vary.. however by far the most common is a 3/4" screwed outdoor tap..
as it's easy to forget and leave it on the tap.. I carry a couple of the first one.. also added to my collection by 'finding' them still on taps.
this adapter covers two sizes 3/4" and 1/2 "
Broken Link Removed
occasional see a 1"
Broken Link Removed
and for round taps..18 mm and 24 mm
Broken Link Removed
Broken Link Removed
Broken Link Removed
scotjimland
2,309
9,979
A Woosh bang
A few types of water supply have a female connector - no tap.
I've seen the taps with a push down valve, they are difficult to connect to.. and you have to stand and hold it while you fill..
but that's a new one on me.. never seen one like that.. is that a new type of bourne ?
Dec 24, 2009
1,072
15,716
bedworth warks
c class
2009 previously a tugger for thirty years
Yes Jim they seem to be appearing more and more these days, We have come across them on the Ile d' Oleron and at Rugles last year there are probably more but these were just two places where we needed to fill up.
The connection is usually close to ground level I think its to stop the watering can users using them. As in the type of people that park close to the borne then immediately dive when you move off to see if there is any water left they can skank for free.
You do have to connect your hose pipe to the connector before you attach it to the borne as there is no tap to stop the flow.
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
I was going to mention the one at Luss but I see you tried there, I would think if your at a waterside location then you would find a tap near where boats are tied up.
We carry a 25L container with us and a 12v pump to pump it into the tank, also carry 25m of hose and so far never been stuck.
scotjimland
2,309
9,979
A Woosh bang
thanks @trophychap (y)
must get back to France soon.. hopefully this year.. getting out of touch with all these new fangled bournes..
sedge
Jul 7, 2009
5,504
13,114
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Those male/male are a PITA if you are too far away from them, although we carry a longish hose. Deciding we didn't want a watering can using space, we started carrying a 10L water carrier we already had - not too big, flat enough to fit in a certain handy place in the 'garage' that was otherwise unused (tapering ledge in there) so can also be carried full if wanted, eg going on to an aire with no borne, or if we just don't know, or indeed, when it's free where we are and tokens where we're going! - and a flexible hosed funnel to just top up as and when if we need to.
I can lift the full 10L and pour it in the tank (ie - into the funnel inserted in the neck of the tank) easily enough whereas anything bigger and I wouldn't - so it's another job I can do on my own rather than Pete having to do it all the while.
Have to add - we have no objection to paying but it depends how easily you can get the wherewithal doesn't it? Actual coinage is fine - but if you aren't in walking distance of the place you get the jetons - or it's very rural and the place is only open eg Tuesday morning and Thursday afternoon and we've arrived Thursday evening and wanted to stay several days ..... watering cans are ideal provided the wherewithal to fill them is on site, but you can't carry extra water slopping about in them, can you!
hebhunter
Perth
McLouis
Since 1998
If in the Inverness area, the Tourist Information Office in the car park in Drumnadrochit has a tap on the outside.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
HI
I have seen a device designed for Holding down the push button type of shower taps Hooks behind the Tap or pipe and uses a screw to hold the tap open.
OR this one? http://www.showerfriend.com/
Pete
11,862
42,941
Planet Earth
A van
Over 25 year's
I only carry 10m hose a twenty letter water can and a jug
Never Ben stuck for water even in the middal of no whare we harvest rain water when it rains boiled for doing the pots freeing up drinking water
I have also used water from burns and rivers boiled.
Boiling kills mos bacterial stuff and a water pure tab will work to
Willdbill
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
We have a 100 litre inboard fresh water tank, 2 x 25 litre containers stored in the top box which are filled if we go off into the unknown and 10 litre and 5 litre bottles in the van, plus every conceivable tap connector We have found so far.
We also have a device for holding down push taps, it's called a re-usable cable tie. :LOL:
Hymie
