Water Tanks
Discussion in 'The Beginner' started by Ruth, Nov 3, 2014.
  1. Ruth
    Ruth Read Only Funster
    Oct 18, 2014
    47
    19
    Gloucestershire
    I'm afraid this is another dumb question that popped into my head, but how do you fill your fresh water tank?I know your answers are going to be simple and obvious, I also know I'm going to feel really silly, but I don't mind:)
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,728
    10,158
    use water from a tap. ideally using a food grade hose to avoid it tainting the water. to top up on a site, i keep a clean 2 gallon watering can for ease of use
    oh and the water goes into the water filler point usually on the side of the van. never to be mistaken with the fuel filler as discovered by too many newbies
    • Like it Like it x 2
  3. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,959
    2,333
    Lincs
    Anything larger than a VW type campervan will have a water fill point on the side - very similar to the fuel fill point (so don't mix them up!). Small campervans have removable water containers rather than fixed tanks, so you can take the container to the tap.
    You can fill by removing the filler cap & sticking a hose pipe in the hole, or use a watering can. Some people use the same rollalong water carriers that caravanners have, complete with a submersible pump to pump the water up & into the filler pipe.
    To make it really easy, you can get a special filler cap that accepts a plug-in hose fitment. (you only put in on when filling). See here for an example.
    There are two different versions, depending on whether your tank has an overflow or not.
  4. Cal54
    Cal54 Funster Life Member
    Apr 25, 2014
    1,457
    9,090
    Lancaster
    I use a 5 litre petrol container for daily top ups on site, obviously bought purely for this purpose and not having had fuel in it! Prefer this to a watering can as the flexible filler pipe is better to access the angle. Main fillng is by the miracle hoses that don't take up any room at all, admittedly not food grade but I never drink water direct from my tank.
    • Like it Like it x 1
  5. icantremember
    icantremember Funster
    Sep 2, 2010
    5,390
    7,494
    Nr Watton in Norfolk
    I agree with Thebig1 in that I use a food grade hose or a garden water can kept specially for this purpose.
    P'S There's no such thing as a "dumb question" on Fun but you sure will get some dumb answers!;)
  6. Pilote87
    Pilote87 Funster
    Aug 14, 2013
    304
    219
    Département 87
    On any vehicle from a panel van conversion upwards in size it is normal for the fuel filler cap to be opened by the ignition key and the water fill cap to be opened by the same key which operates all the other locks.
    Of course, there will be some exceptions to this.
    J
  7. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,352
    10,250
    Lorca,Murcia,Spain
    On mine the door locks & fuel cap are the same key & the ignition , habitation door, leisure batter, water tank & onboard gas tank all have there own individual keys.
    yes ,that's 6 keys !:LOL:
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,089
    17,759
    YO11 2BD
    But is the watering can also food grade ?
    Water isnt in a hose long enough to pick up any leached chemicals whereas the watering can needs to be carried for some distance full of water....but it still wont pick up chemicals unless you leave it for hours before filling.
  9. TheBig1
    Nov 27, 2011
    7,728
    10,158
    cant remember the acronym for the plastic used in the watering can, however i did check and the plastic used is non toxic. same stuff the tank is made of. the flexible liner of a garden hose however is made of a plastic known to leach carcinogens into the water. plus the water has a bad taste
  10. icantremember
    Sep 2, 2010
    5,390
    7,494
    I always flush the hose through before use and I never leave water in the watering can but pour it straight into the tank.
  11. gozomike
    gozomike Funster Life Member Life Member
    Mar 16, 2010
    876
    663
    Warwickshire - sometimes - but not often
    As mentioned a few have mixed up the fuel & water inlets. I think it is worth keeping the water filler key with the hose to save confusion.
  12. cranky
    cranky Funster
    Oct 29, 2012
    415
    491
    essex
    with a bucket, dear Liza, dear Liza with a bucket:)
  13. jdk62
    jdk62 Funster
    Aug 19, 2014
    580
    1,172
    If I don't have enough water, I just dilute it....
    :D
  14. rosierose
    rosierose Funster
    Apr 29, 2014
    1,133
    3,453
    oop North
    Those that replied - Re tainting the water from using a hose pipe etc, if you are just using the water for washing up, showering and loo does it really matter? Or are you drinking it?
  15. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,825
    11,992
    Kettering
    I use a food grade hose where I can and where this isn't practical I have an Aquaroll, a 14 year old to go and fill it, and a 12V pump. Either way no heavy lifting or manual labour involved (y)
  16. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,940
    12,195
    Plympton, Devon
    We use a hosepipe when possible and carry a fold flat one on a reel in the van. Always flush it through first to dislodge any spiders but we don't use this water for drinking, only washing etc.
    For topping up when no convenient tap available we have a folding bucket, ( using a different coloured one for emptying waste) and to get it in the tank I have a small funnel with a bit of hosepipe glued on the end. Fortuitously, the funnel hooks onto the window frame above the filler and stays in place.
    Main aim for us is to have stuff which takes up the smallest volume.
  17. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,929
    3,394
    Eastbourne East Sussex
    I have 3 different length hoses which can be joined together (food grade as we use our water for tea etc), watering can and an aquaroll and pump. The filler cap with a hose connector on is brilliant (though overpriced for what it is).
    I usually try to travel with a full tank, filling up when I leave a place also emptying grey/toilet tanks, so as to be OK to stop wherever without worrying about whether there is any water at the next place I stop. There are aires that don't have water, or have water but needs a jeton which is only available from a place that is closed, or in winter the taps may be frozen or turned off (we've had this in the UK in the winter).
    An aquaroll takes up a lot of space but if the space was liberated SWMBO would fill it with something a lot heavier.
Similar Threads
  1. Spanda
    35
    766
  2. Job63
    13
    795
  3. Mike foster
    23
    919
  4. Yomper
    3
    549
  5. The Old Man
    25
    1,662
