Water Tanks ? (1 Viewer)
Alonsos
177
15
Devon Somerset border
Auto trail t615
Since 2008
chausson welcome suite 2010
Hi you lot
Problem (wouldn't be fun otherwise)
Control panel reading Waste full when it's empty
Control panel reading Fresh water empty when it's full
Probes in fresh water tank were a bit lime scaled & touching the side of the pump , removed unit and cleaned & refitted properly ( some muppet been playing with it before & put back badly) all sorted now,
But it's almost like someone's reversed the connections ,I've filled freshwater and it reads empty,
I've not put anything back wrongly the readings were odd to start with
Ime now into head scratching & getting splinters in my fingers
Anyone encountered this problem
I did previously have a panel van and you could remove control panel and reboot it but don't think that would solve this one .
Take care Alon sw/ uk
R
Robert Clark
Worth using some Fenwicks tank cleaner in the waste tank as the sensor is probably mucky - had the same problem on my van
Alonsos
Alonsos
177
15
Auto trail t615
Since 2008
Cleaned sensor already it's spotless mm!
Thanks for reply
Jul 12, 2013
3,869
5,262
The City of Henlow
Adria Supreme
Since 1980
Sorry if I am missing something but have you any evidence that either sensor is working other than offering the wrong information?
Is there any possibility that the wires are wrongly connected behind the panel?
Would the polarity make any difference?
I ask these questions because you implied someone had been 'messing' with the wiring.
Alan
Alonsos
Alonsos
177
15
Auto trail t615
Since 2008
All things are possible just looking at the obvious things 1st ie probes , I've had van a week I can see someone's had tank sensor out by the poor way it was refitted etc , I've had control panel out , no resets just printed circuit,I've unplugged & replugged ie reboot , it's not that , next yes probably the wiring , a process of elimination really .
