water tank leak (1 Viewer)
Sep 4, 2011
2,664
6,754
No more
We have a leak coming from the fresh water tank under the van, where the drainage hose meets the plastic grommet, the grommet then connects to the tank:cry: I've tried to seal it but it just isn't working so I think a new tank will need to be fitted :Doh: does anyone know where I can get one fitted as I suppose it would mean putting the van up on hydraulic ramps for easy access to work on :Sad:
Rob&Jane
old-mo
Extra Special
16,343
93,570
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Have you got an inspection hatch on the top... ?
If so cant you put a new fitting in... :Cool:
ROB1CHELSEA1
Sep 4, 2011
2,664
6,754
No more
Can't find one anywhere mo:Sad:
teddybard
7,448
8,695
warwickshire
c
5 years
Hell Rob.
If you didn't have bad luck you wouldn't have any.:Smile:
I'm Told Grommet is unreliable:ROFLMAO: ( He drinks you know.):winky:
On a serious note try the
Gnomeahome forum (cant remember the technical name)
http://************************/ftopic-68995-0.html (its the Dark Side)
Best of Luck
Roger & Sheila.:Smile:::bigsmile:
43,302
49,289
If the tanks is underslung then the large access hole Mo mentioned will probably be on the top, if it has one, and the tank will need dropping to get to it.
Easy enough to remove the existing outlet and fit a new one.
ROB1CHELSEA1
Sep 4, 2011
2,664
6,754
No more
Just been and had another look, the fresh water hose where I pour water in runs at the back of a cupboard, then turns a little way and runs behind the fridge:Doh: so then must drop down in to the tank. Can't pull fridge out as its sealed in place. Our sink is directly above the fridge.
ukbill
5,501
5,274
Pinoso
4 berth low profile
starting on saturday 10/3/2012
if u can hold out till malvern will take a good look at it there for ya rob
GJH
29,450
38,827
None, now sold
2006 to 2022
MMM Review (last page under Life Support) confirms that the tank is underslung I'm afraid.
ROB1CHELSEA1
Sep 4, 2011
2,664
6,754
No more
Have drained the tank and removed hose, grommet/plug. Cleaned and dried all bits and area, then refitted grommet/plug and sealed it:thumb: will wait till tonight till sealant is fully dry and then add a little more sealant. Will fit hose back on on Sunday morning. Then fill tank with fingers crossed.:RollEyes:
The main water filling pipe does run behind the fridge and then exits the van and is connected to the side of the water tank near the top, its amazing what you find out when laying on your back in the gravel:ROFLMAO:
Rob
ukbill
5,501
5,274
Pinoso
4 berth low profile
Rob
yeah linda found a damp patch in the bedroom ceiling while on her back :ROFLMAO:
