Water tank insulation.
Discussion in 'Motorhome Chat' started by Kanberlingo, Oct 24, 2009.
  1. Kanberlingo
    Kanberlingo Read Only Funster
    May 18, 2009
    91
    Lancashire
    Hi all,
    What are members thoughts on the necessity to insulate the water tanks. We are spending 3mths in Breamar Scotland from mid Dec. to late March, & what material would be used if considered necessary. We have the 2007 Chausson Allegro83
    (57 plate)
    BeeJay
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    if its indoors then no need.
    if its underslung then it may well be worth it.
    closed cell foam sheets (you dont want it absorbing water)would be a good bet and this could even be glued to form a box using a rubber adhesive
  3. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    If it's only the waste tank I would not bother, I would leave the tap on drain hose open and use a bucket if you expect freezing temps. At least the waste should not freeze.
    Fresh water different use pappajohns method if tank outside, or get tank heater.
    Dave:thumb::thumb:
  4. Kanberlingo
    May 18, 2009
    91
    Lancashire
    Thanks pappajohn, I'll source some & fit it to the fresh water tank, if I can get at it.
    I'll go alaong with DESCO's thoughts on the waste tank.
  5. Tony Lee
    Tony Lee Read Only Funster
    Sep 28, 2008
    274
    If temperatures are likely to be below freezing at night and at or only slightly above freezing in the day, then just insulating external tanks will only work for a day or so. Much longer than that and you will need some form of tank heating that includes any external pipework as well.
  6. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    A method I have used, a little more expensive, a little more profesional, can be painted, waterprove if not injured.
    Cans of spray foam will do a fine job. if you wanted to you can clad the foam in very thin plywood as the foam setts and you will have stone protection as well.
    Doug...
  7. Kanberlingo
    May 18, 2009
    91
    Lancashire
    A few alternatives to consider. Thanks chaps.:thumb:
  8. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
  9. Kanberlingo
    May 18, 2009
    91
    Lancashire
    Hi American Dream,
    That link is A1, but trying to find a similar site in the UK is proving to be difficult.
    All that is being thrown up are heater type mats etc for hydrophonics, fish tanks etc.
    No matter how I type in the request for Google, I can't find a site that gives the same type of heater mats as your link.
    I'll post-up if/when I find one.
  10. DESCO
    Mar 11, 2009
    2,651
    267
    London
    Might be worth looking in caravan spare part suppliers I am sure have seen something like a 12V submersible heater like used in fish tanks but can't remember where, that does the same job.
    Dave:thumb::thumb:
  11. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    I have a Chausson Welcome, built similar to OP's Allegro.
    The freshwater tank is inboard and should be frost free and no danger of freezing. The waste tank is underslung and, as mentioned previously, if the drain valve is left open to drain into a bucket or similar then, again, no problem.
    The Allegro is a French model and very popular with the French when going into the Alps for winter skiing. Also you should check to see if the waste tank already has a heater. After all the Allegro range is top of the model line-up and has lots of 'bells and whistles' that other models don't have.
  12. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    do bear in mind these heaters draw a minimum of 4 amps your poor batteries will soon be flat if you are not on hookup
    internal tanks will still freeze if you don't have heating on inside. Best to fill the tanks with whiskey then no more problems.:Rofl1::Rofl1::Rofl1::Rofl1:
  13. Kanberlingo
    May 18, 2009
    91
    Lancashire
    I like my Whisky (Scottish) with a dash of water, thats why I need to keep the fresh water tank liquid. :Rofl1::Rofl1::Rofl1:
  14. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    If you leave the drain tap open as the last drops come out they will freeze eventually blocking the pipe. Better to let the tank fill then empty it all in one go, of course this all goes tits up if you are always emptying hot water :Rofl1: (melting the said ice)
    My own tanks are under slung surrounded by some thick (30 mm ) solid -ish foam that does not soak up water (no idea what it is called ) and on the inside I leave a dish cloth in a bowl a couple of inches deep in bleach and water that has yet to freeze (2 yrs winter ) and never bother draining the boiler, but then again my baby is a lot better insulated than any normal van :BigGrin::Wink: -- see insulation at the bottom of description--:thumb:
    terry
  15. activecampers
    activecampers Read Only Funster
    Jul 28, 2008
    420
    102
    Heathrow
    cak tanks sell 15w tank heaters, and combined with insulation should be good for -26. Thermostatically controlled. I've been in -11 and its been fine.
  16. Kanberlingo
    May 18, 2009
    91
    Lancashire
    @ Spacerunner, I can't see anywhere in the bumf that came with the MH that there's a wastewater heater fitted, nor is there an obvious switch to be seen.
    @Terry, The drain on the Chausson isn't a tap, but a sluice similar in size to the sluice in the Thetford toilets. It's opened & closed with a pull/push bar from the side of the bodywork.
    @ Activecampers, I've dealt with CAK Tanks in the past. I once fitted an additional freshwater tank to a Fiat Compass Ducato we had. So I'll take a look at their site.
    Thanks again to all contributors.
    BeeJay
  17. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    Hi BeeJay ,If you leave the sluce open it will still freeze the last dregs of water probably creating another problem by not allowing you to close it :cry::cry::Rofl1::Rofl1:
    terry
  18. Kanberlingo
    May 18, 2009
    91
    Lancashire
    B*gg*r it, I think I'll stop at home. :Rofl1::BigGrin::Rofl1::BigGrin::Rofl1: Where's that scotch?
  19. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    It's in your water tank:Rofl1::Rofl1::Rofl1:
