Water Tank Indicator problem? (1 Viewer)
Reaynger
38
38
Caithness
Peugeot coachbuilt.
I'm a newbie
Hi, I drained the fresh water tank for a weeks duration and partly filled it with perhaps 10 litres from a campers water bag using the wee pump because silly me lost the fitting to connect with the hose. Trouble is the needle meter thingy reading high like as if it is brimfull, can anyone have an idea what the problem is or am I overlooking a simple fix. I'm thinking some device inside the tank is stuck but have no idea how to unstick it. Thanks in advance. :Smile:
rob kinnear
175
31
Swansea
Hi Top
1 year 10 years tugger
Hi and :welcomefunster:
My water level has never worked properly and from other post's I have read they do not always work. I fill mine and either look at level through inspection hole or until it over flows.
Others may be along with a answer soon
Best of luck
Rob
:thumb::thumb:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
most tank level sensors are a combination of probes of different lengths it could be you may have got a spider in your tank and it has spun a web across these probes thus making them read full.
43,328
49,441
never accurate, waste of time and not worth bothering about.
best indicator there is....if water comes out the tap you have water, if it doesnt you are out of water.
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Depends on the age of the vehicle in question really
The older ones had a float, then the middle aged ones ( !! ) had a lovely system of a float with a magnetic strip on it that rose and fell on a plastic tube.. That tube had reed relays inside it that were switched on when said float was beside of the relays.
The newer ones are probably the most reliable as, just as Aba said, they are just a sensor from which the signal is amped up to give you a read out
Best advise as a quick try would be to fill the tank right up and let the levels drop naturally
Very often that will cure most evils :thumb:
Rob, what year is your van ?
Perhaps the gauge would be easier to repair than you think :Smile:
rob kinnear
175
31
Swansea
Hi Top
Hi Jaws
My van is a 2002 swift sundance
Rob
