Water tank help needed
Discussion in 'Motorhome Chat' started by Reallyretired, Aug 21, 2010.
  1. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,063
    3,469
    Eastbourne East Sussex
    :Eek!:
    The water tank on my 3 year old Rapido 999M has developed a split. This was caused by one of the 'feet' of the tank being missing, probably from new, which caused it to bear on a bolt head anchoring the seat belt post.
    I have tried repairing it without success, and Johns Cross parts department tell me they cannot order this part (for reasons not entirely clear to me - Peter do you know?).
    So far this has cost me £45 for a local caravan repairer to come out and attempt to repair it, another £40 for a roll of Endurobond tape to attempt repair and another £100 for a tank from C.A.K. which doesn't fit.
    The manufacturers in France appear to be shy about their contact details.
    Help needed as I now have a £60k motorhome which I can't use :help::help:
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
    Hi I have done a successful repair using pipe - solvent weld ( plumbers use it on soil pipes - from screwfix or plumbing merchants )then covered it all with a 2 ins bigger flat plastic patch :thumb: belt and braces type thing
    terry
  3. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
  4. acting_strange
    acting_strange Banned
    May 16, 2010
    3,398
    2,568
    North Hykeham
    You can buy flat plastic from any good modelling shop
  5. Reallyretired
    Apr 27, 2008
    6,063
    3,469
    Thanks for this. I will have to try it as tank is polyethylene rather than the ABS the soil pipes are made from. Also unfortunately the spilt is not flat, goes round an angle.
  6. acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    there is a way of gluing/repairing polythene as well....let me know if you need to discuss it....again it comes from my modellling...
  7. acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
    You can buy plastic angle :thumb:
    terry
  9. Mixter
    Mixter Read Only Funster
    Dec 2, 2009
    254
    Keighley, West Yorkshire
    While im sure these tanks can be repaired - and im all for not shelling out if i can possibly help it, im not sure about 'bodging' a mobile tank in a MH. If it was static somewhere, maybe? But, with the water sloshing around, and the bumps and vibrations going on, i dont know if id be totaly confident the repair was going to hold, as the consequences of 10 or 20 gallons of water spilling out all over the van dont bear thinking about.
  10. Reallyretired
    Apr 27, 2008
    6,063
    3,469
    Any help welcome. I would prefer to get a replacement tank if possible but may have to attempt another repair.
  11. acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
  12. welsh winger
    welsh winger Read Only Funster
    Jul 7, 2009
    231
    58
    Sunny Swansea
    Have a look in yellow pages for a firm that does plastic welding, radiator repairers are a point of call.
    Then you have a perminant repair.
    Nick
  13. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
    You have to make sure the glue will stick to both tank and patch :thumb:I have also used Ecoseal 502 - like Sikaflex- to seal a hole in a 5 gallon tank in which to pour diesel in with a ali patch screwed to it :Rofl1: No idea how long that lasted as it was only used 2 days until a new 5 gallon container was acquired but it got us out of a fix at work :thumb:
    terry
  14. CG235
    CG235 Read Only Funster
    Feb 25, 2010
    6
    Nottinghamshire
  15. Glynn
    Glynn Read Only Funster
    May 2, 2010
    163
    18
    Lancashire
  16. Reallyretired
    Apr 27, 2008
    6,063
    3,469
    Thanks for your help.
    The Rapido tank is a very strange shape as it fits around the metalwork of the seat belt anchorage. As a result a standard tank will not fit in the space unless it is very small.
  17. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,418
    5,442
    East Sussex 01-580-881288
    Hi,
    We do not have any facilities to order Rapido parts direct from Rapido as we are not appointed agents for them, if we need Rapido parts we would order them from Caravannes Rapido, Wokingham 01189-9791023, suggest you give them a ring.
    Peter
    • Like it Like it x 1
  18. Reallyretired
    Apr 27, 2008
    6,063
    3,469
    Thanks Peter, the reason was not explained to me. I have emailed Wokingham and also Rapido in france, hopefully with results after the weekend.:thumb:
  19. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,418
    5,442
    Dunno about email, best to ring them and ask Paul.
    Peter
  20. xplor
    xplor Read Only Funster
    Feb 18, 2009
    Rapido 999M Water Tank Split
    Hi,
    We have just encountered the same problem with our 4 yr old Rapido 999M. Can you tell me what the outcome was with yours? Is there anyone that knows a mobile plastic welder repairer in Reading/Wokingham area? We were just setting off on a weekend break when the water started leaking everywhere. have taken it ti Caravannes Rapido in Wokingham and they are going to try a resin repair but are not sure that this will work. They are going to try this out in the hope that it will work so that we can go on a 3 week holiday next week. They have rung Rapido in France who cannot provide a replacement for 9 weeks!
    Does anyone else have any ideas should this resin not work?
