Water tank gauge
Discussion in 'Motorhome Chat' started by The rehctub, Sep 12, 2016.
  1. The rehctub
    The rehctub Funster
    Sep 20, 2014
    81
    18
    Luton
    Have a Autosleeper Cotswold
    the water tank gauge is not given any readings always says empty
    Have been told we need to descale inside to clean terminals that give water level readings
    My question is what would I use to descale tank ?
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,782
    10,198
    white vinegar
  3. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,176
    1,288
    Dronfield - Derbyshire
    You might be able to reach inside the tank and actually clean the probes
  4. scotjimland
    Jul 25, 2007
    28,941
    25,633
    Citric Acid..
    white vinegar can leave a taint that's hard to remove.
  5. musson
    musson Funster
    Dec 25, 2013
    409
    143
    grantham
    I had to clean mine if you can reach put some brake cleaner on a rag,have to be quick as drys quick
  6. Philh
    Philh Funster
    Jan 22, 2011
    75
    33
    Cheshire
    I had the same issue, I just reached into the tank and wiped them with a clean cloth. Anything you use will taint the water or worse. I would not want to use any water that had been in contact with brake cleaner, have you seen what it does to a car's paintwork?
  7. The rehctub
    The rehctub Funster
    Sep 20, 2014
    81
    18
    Luton
    It's not possible to " reach in to tank " is it mine has a trauma pump to load water in to it ?
  8. BONZO
    BONZO Funster
    Mar 1, 2012
    288
    194
    Rotherham
    Whet about cock a cola ?
  9. campa cola
    campa cola Funster
    Oct 5, 2012
    2,991
    5,882
    Weegeland
    I'd rather drink residual brake fluid......
  10. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,176
    1,288
    How did they fit the level sensor in the first place? If some one screwed it in then you should be able to screw it out.
    Just an idea
  11. daveinspain
    daveinspain Funster
    Jun 23, 2011
    98
    69
    Pedreguer, Spain
    Mine unscrews and lifts out for descaling - there is a large nut underneath accessible through the large ports in the tank.
    • Like it Like it x 1
