Water supply problem ...
Discussion in 'Tech/Mech General' started by St.Cyr, Jun 28, 2010.
  1. St.Cyr
    St.Cyr Read Only Funster
    Aug 23, 2009
    49
    3
    West Wales/Normandy
    Hi all.
    Could anyone come up with any ideas why our taps and shower won't work since the big freeze last winter? We drained everything down as far as possible but now the microswitch operated taps won't work. Wondering if water may have remained in the pumps and frozen, damaging sonmething?
    Any suggestions at all would be gratefully received!! :thumb:
    (checked fuses etc)
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,959
    17,634
    YO11 2BD
    certainly sounds like frost damage if the fuses are all ok.
    it could have split the pump/filter casing but probably would push water onto the floor, unless its a submerged pump (in the tank) if its a diaphram pump it could have damaged the valves or diaphram.
    can you get to the pump ?
    identify the feed wires to the pump and test with a mutimeter with a tap turned on.
