Water sensor probes AT Cheyenne 2004
Discussion in 'Tech/Mech General' started by irnbru, Apr 3, 2016.
  1. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,852
    11,061
    Glasgow
    Please can someone tell us how do you get to the probes on this model? Does the tanks have to be dropped? Both water levels dont seem to read correctly. Have tried to clean with coke but no use.....and can anyone explain the control panel. When the waste level reads 100 and you press the middle button and hold it in for 5 secs it then reads waste level 2 =50%
    So then if you turn it all off and on again it still reads the latter...As if I have changed it...puzzled.
  2. rb62
    rb62 Funster
    Nov 5, 2013
    456
    6,649
    Shropshire
    When we went on the factory tour I asked where the fresh water sensors were on a Savannah as they had a base chassis there with the water tank fitted
    ...........they couldn't find them!
    To be quite honest I think it's a case of water in = water out! I replaced the waste tank sensor and it only lasted 6 months.
    Notoriously unreliable.
    • Like Like x 1
  3. irnbru
    Jun 27, 2013
    5,852
    11,061
    Glasgow
    Where is it Richard? How did you replace it?
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    Think he is trying to say don't bother Sandra :D You should be able to get to them through the big unscrew bung ;)
    terry
    • Like Like x 1
  5. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,615
    22,792
    Narrfoook
    The control panel is a universal thing that is used on lots of builds.. some will have twin waste tanks.. There is also provision on some to choose internal or external pumps !
  6. irnbru
    Jun 27, 2013
    5,852
    11,061
    Glasgow
    But where is it?
    Thanks that probably explains the control panel
  7. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,043
    11,564
    East Sussex
    On our Bessie, the big screw cap was accessed via a lift up panel in the floor.
    With the cap removed you could see and feel the sensors
    The waste tank screw cap could only be accessed from under the van. With the cap removed the sensors could be felt.
    We found that by cleaning both tanks with 'proper' Elsan tank cleaning fuid that both sensors started to work properly again
    To prevent further problems we always empty the fresh water tank between trips and use Dish'n'treat which is a washing up liquid that is also a tank and pipe cleaner
    • Useful Useful x 1
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    Hi Sandra it will have a couple of wires attached hanging down from the top of the tank -If your large bungs are at the bottom of the tank you can unscrew it and it should give you access to it -if not drop tank to get at it
    -Better to listen to your pump tone and you will hear when it's getting close to empty (y) filling wise stick hose into filler and when water comes out of filling hole, think it's full:LOL::LOL:
    • Funny Funny x 1
  9. rb62
    rb62 Funster
    Nov 5, 2013
    456
    6,649
    Shropshire
    The waste sensor was a float switch,push fit into the side of the tank.Ours was a 2010 van so might not be the same but was accesible from under the van.If you find it make a note of which way up it goes,ours had a flat side to it.
    If you find it make sure your waste tank is empty before removing it. :LOL:
    • Funny Funny x 1
  10. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,627
    2,135
    Scotland
    No idea where they are Sandra but have you changed your van?
  11. irnbru
    Jun 27, 2013
    5,852
    11,061
    Glasgow
    No and we aint gonna :) ItsAlans MH that has the problem but since im on the forums so much Ive been given the task of getting the info :)
  12. Gellyneck
    Jun 5, 2014
    1,627
    2,135
    Scotland
    Ahhhh.(y)
