The Lobster
- Aug 13, 2011
- 321
- 325
- Bürstner A576
- Still getting started
I have a water valve that is closed when the temperature in the van goes too low - and then it dumps all the water in the tank. This prevents us accidentally leaving water in that might freeze.
Now it's started dumping water - but only when the water pump is activated (e.g. by turning on a tap). The valve is definitely at the "open" (not triggered) position, and if I manually move it to "closed" (triggered) it starts to dump water as it should, whether the pump is on or not.
Any ideas anyone? Thanks.
Regards
--Andrew
Regards
--Andrew
