Water Pump (1 Viewer)
Spinout
30
London
Coachbuild
Newbie
Ok so I want to turn the cold tap on and get water - sounds simple enough but I don't seem to be able to do this.
Maybe my pump is broken? Or that I have not turned something on?
Many thanks :thumb:
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
cant see a pump switch in any of those piuctures you need to find the pump and follow the wiring back to find the switch of fuse
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Covered this with an answer last week. If only one tap is playing up, and then either hot or cold, but everything else is running fine, check the spade terminals below the sink. Happened to us last time out. A spot of WD, waggled the terminals into there connectors, and all worked fine. :thumb:
