Water pump (1 Viewer)
jordano
170
8
blackpool
Triango CI Cipro55
3 years
Can anyone help with my problem water pump starts then stops after 30 seconds after about ten mins it will start again then stop tank is full and batt is fully charged only thing is we are not on level ground can this cause a problem with the pump?
denisejoe
5,617
12,051
Warden isle of sheppy
Since 2004
Sounds as though pump is repressurising the system have you got a loose joint it could be anywhere even in the pump you could turn the pump off until you need it
Joe
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
Yes water coming out as usual then stops
funflair
19,344
30,223
Guisborough
MORELO palace
since 2012
What sort of pump is it, in tank or external sureflo, does it wirrr or go bump bump bump.
Martin
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
It's a Shurflo have drained system there is a twist on strainer on the inlet
