Water Pump Noise
Discussion in 'The Beginner' started by ChrisMac, Jul 20, 2015.
  1. ChrisMac
    ChrisMac Read Only Funster
    Apr 14, 2015
    47
    15
    Aberdeen
    We have a new Elddis. When switched on, the water pump makes a wee grumbling noise every 30 seconds or so. Just want to confirm that it's normal for it to do that? Thanks.
  2. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    465
    591
    Nr Hastings, East Sussex
    I don't think so! Assuming that you've run water through the system (hot & cold) to expel any air then it sounds like you're losing pressure somewhere. Chat to the dealer.
    • Like Like x 1
  3. scotjimland
    Jul 25, 2007
    28,936
    25,589
    check there are no drips at the taps, not forgetting the shower mixer..also feel along the water pipes for any sign of wet, particularly under the sink and where the pump is mounted..
    all it takes is a few drips for the pressure to drop sufficiently for the pump to kick in..
    • Like Like x 1
  4. ChrisMac
    Apr 14, 2015
    47
    15
    Aberdeen
    Just had a look at the pump. There's a clear plastic bit with what looks like a filter of some kind in it. There appears to be a lot of dirt in there which doesn't look right. I'll get in touch with the dealer. Thanks for the advice folks, this is my first stop for questions.
  5. scotjimland
    Jul 25, 2007
    28,936
    25,589
    that is the filter.. the clear bit unscrews and you can wash it out .. you must have picked up some dirty water.. drain the tank, flush and refill
    • Like Like x 1
  6. ChrisMac
    Apr 14, 2015
    47
    15
    Aberdeen
    I'll give it a bash, thanks for that.
  7. chaser
    chaser Funster
    Feb 16, 2013
    7,295
    7,990
    uttoxeter
    Doesn't really explain the pump kicking in though
  8. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,557
    7,064
    Plymouth
    Personally we turn the pump off when not in use and open a tap to relieve pressure then close it again no wet suppress then after a long stint of travel.can you turn your off ?:)
  9. Brian_K
    Brian_K Read Only Funster
    Feb 9, 2015
    272
    246
    Durham
    Mine does exactly the same. To be honest I just switch the pump off until needed.
    Brian
  10. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,407
    5,221
    St. Helens MERSEYSIDE
    Hello if yours is a new van the stuff in the pump filter is more than likely to be plastic turnings from when the tank fittings were put in ie.swarf.
  11. bungy
    bungy Funster
    Jan 24, 2010
    2,249
    4,138
    Welsh marches
    just fixed something like this on ours, changed out the pump valve and all sorted = £15
    simple DIY job
  12. scotjimland
    Jul 25, 2007
    28,936
    25,589
    no but.. I already answered that question ..
  13. Huckleberry
    Huckleberry Funster
    Mar 20, 2015
    5
    6
    Essex
    I have the same problem a 2015 Adria Coral fitted with a Whale Pressure switch. I have taken it back to the dealer twice, first time the pressure switch was replaced, I am not sure what they did on the second visit as I had some other snagging jobs done at the same time. Whatever they did has not worked and I wil be contacting them again. I will be watching this thread with great interest!
    Rodger
  14. Ethle the wondervan
    Ethle the wondervan
    Mar 13, 2015
    204
    649
    Peak District
    There's no time for that sort of filth!
    Fix your water pump first!!
    • Like Like x 1
  15. ChrisMac
    Apr 14, 2015
    47
    15
    Aberdeen
    I think you're right, there are other bitslike that on the floor around the pump.
  16. ChrisMac
    Apr 14, 2015
    47
    15
    Aberdeen
    Yip, we've been switching off the pump when not needed. I just wondered if it was a big problem, heading of yo Europe end of August for a year so want to get everything sorted before then. Going to clean out the valve and see how it goes.
  17. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    If it's done it from new it's probably the pumps pressure switch.
    The actual pressure can't be changed but the point the switch kicks in and turns off the pump can be altered.
    • Like Like x 1
  18. etap
    etap
    Nov 19, 2014
    256
    233
    Somerset
    I take it the water tank has enough water in it, because many times it happens when the pump is starved of water, either by lack of water or muck in the line, also air in the system which can be cleared by ensuring the taps are running smoothly.
    Etap
  19. ChrisMac
    Apr 14, 2015
    47
    15
    Aberdeen
    Yes, plenty water in the tank and taps running smoothly.
  20. ChrisMac
    Apr 14, 2015
    47
    15
    Aberdeen
    Pump finally packed up last week, luckily it was already booked in yo the dealer - new pump installed and all appears well, apparently a fairly common problem with the whale pump. Thanks for all the advice folks. That's us ready to head to Europe on Monday for a year.
