Water pump noise, Bessacarr E560
Discussion in 'Motorhome Chat' started by Guy, Jun 10, 2009.
  1. Guy
    Guy Deleted User
    Have a 2008 Bessacarr E560 with a water pump that causese people to duck when operated - sounds like a machine gun!! Any suggestions? Rubber mounts seem ok but maybe a little stiff! :Sad: Other than that the MH is super except for the reverse reversing camera, which Swift have willingly agreed to change.:Smile:
  2. sinbad1
    sinbad1 Deleted User
    Hi and :welcome:There can be several reasons why water pumps make noises
    could be that the pump bearings are worn ( check if it gets hot)
    could be the mountings ( unscrew from the mountings see if the noise dissapears)
    could be air in the system causing pipes to vibrate ( ensure all taps are bled and pipe runs securred)
    If the pump is worn out a replacement would be reqired. What make of water pump do you have?
    Regards
  3. Johno
    Johno Read Only Funster
    Oct 29, 2008
    88
    38
    Kent
    Hello Guy
    Sometimes the screws holding the pump to the rubber dampers have been tightened to much which limits the damping effect of the rubber mountings, try slackening slightly to see if it helps it's one of those trial and error things until you get it just right.
    Regards John.
  4. Guy
    Guy Deleted User
    I will try this later this week and let you know. Cheers:Smile:. Otherwise I have some idea of mounting unit in similar fashion to an ABS module. Will let you know outcome if interested.
  5. Big Brian 56
    Big Brian 56 Read Only Funster
    Dec 12, 2007
    17
    Morley
    Ours has always been noisy from day one, not as bad on 12 volt only, thought about putting a polystyrene box round it.
  6. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,427
    East Sussex 01-580-881288
    Hi,
    You need to try and insulate it from the mounting board which acts as a 'drum'
    A section of hose pipe can work. Mount the pump on one side of the pipe (nuts and bolts) and then fix the pipe to the board using wood screws, cut the ends of the pipe diagonally for mounting on board.
    Peter
  7. Guy
    Guy Deleted User
    Will definately try this one as its a far less complicated than what I was planning. Cheers!:BigGrin:
  8. Jim
    Jim Ringleader
    Jul 19, 2007
    26,721
    79,005
    Sutton on Sea
