Water pump noise airlock!!!!
Discussion in 'Tech/Mech General' started by Paul and Kate, May 27, 2016.
  1. Paul and Kate
    Paul and Kate Funster
    May 1, 2016
    192
    573
    Stoke on trent
    Hi our majestic 155 is 2 weeks old and from new the water pump is making a kind of knocking noise
    I thought it maybe airlocked but it's still doing it
    It does it on the toilet flush
    Hot and cold taps in shower room and kitchen
    We are back in Tewkesbury later on in June so it could go back to them to sort out but thought I'd ask here if there's something I could do to resolve the problem
  2. scotjimland
    Jul 25, 2007
    28,934
    25,602
    If it's a ShuFlo type pump and not a submersible pump, then they are quite noisy.. all depends on where and how they are mounted..
    it may just need sound proofing or the mounting screws are too tight.. there should be rubber pads under the feet.. or it could be pipe knocking against a wall..
    have a look when it is running to determine what where the noise is coming from..
  3. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,613
    22,768
    Narrfoook
    Yup.. They are a tad noisy !!
  4. TerryL
    TerryL Funster
    Mar 5, 2010
    1,404
    1,386
    North East
    Most likely the pipe from the pump knocking against a bulkhead it passes through. Try tracing it through from the pump a short distance. Bit of bubble wrap or other insulation should cure it. Pump noise is usually more of a heavy vibration and can be a bit of a b****r to fix.
    Happened to me when we first got our van.
  5. Paul and Kate
    May 1, 2016
    192
    573
    Stoke on trent
    Well we got home yesterday and decided to take a look at the pump
    My theory which may be wrong is that
    The underslung fresh tank has the pump feed tube coming up through the floor then arcs into a pump pre filter with a gauze in when the pump runs in seems to empty the filter and then draws the water in from the tank and can't keep up with the pump this then causes the noise
    What do you think
  6. scotjimland
    Jul 25, 2007
    28,934
    25,602
    I think it is sucking in air at the filter.. . check the filter for cracks.. quite common for them to suffer frost damage..
    spare filters on eBay.. is it like this ?
    http://www.ebay.co.uk/itm/SHURFLO-F...ING-255-215-/171049149102?hash=item27d352e2ae
  7. Motorhome Man
    Motorhome Man Funster
    Mar 2, 2016
    69
    159
    Upper Halling, Kent
    Hi, it could also be a blockage or kink in the pipe from the tank to the pump, or even a blockage in the tank.
    Try installing a pipe from a container to the pump and see if that cures it. Regards Luke
