Water Pump keeps switching on for a split second.
Discussion in 'Tech/Mech General' started by Craig Rogers, May 1, 2012.
  1. Craig Rogers
    Craig Rogers Read Only Funster
    Nov 9, 2011
    651
    411
    Midlands, UK (Welsh!)
    About every 10 minutes, the water pump keeps switching on for a split second as if the pressure is dropping. I've checked and can't see any water leaks which would make sense. Anybody else got any ideas?
    In case it was just an air lock causing it (maybe?), I've drained the system all down, so it might not do it when I refill, but thought I'd check if anyone knows?
  2. Jim
    Jim Ringleader
    Jul 19, 2007
    26,418
    78,071
    Sutton on Sea
    You have a leak.. you just need to find it:Smile:
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,342
    7,467
    Nr Watton in Norfolk
    It certainly sounds like a small leak somewhere or a tap dripping
  4. Scotties
    Scotties Funster Life Member
    Sep 23, 2008
    359
    164
    Norfolk
    Common one is the Thetford solenoid allowing water through, leave 12v on when stood up a couple of weeks and see if you get a full bowl of water. :Eeek:
  5. capinpugwash
    capinpugwash Funster
    Sep 14, 2008
    515
    630
    Hampshire
    I have the same thing and found that the frost release valve for the hot water tank has a slight drip (a weep really).
    Over the course of say 10 minutes the pressure drops enough for the pump to kick in for a second.
  6. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    Voltage low ? would that cause it?
    pump seals?
  7. Loujess
    Loujess Read Only Funster
    Jan 10, 2010
    3,261
    3,168
    Leeds UK
    Our leak was under the basin in the bathroom. :BigGrin:
    Ivy
  8. Craig Rogers
    Nov 9, 2011
    651
    411
    I've just had a thought.............. I may have nudged the hot water draindown valve whilst we where away, I'm thinking that there may have been a small leak from there..........
    Thanks for your help all.
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,758
    6,253
    South yorks
    Hi Craig the pump seals may be going allowing it to loose pressure :thumb: you can get a kit :thumb: or a new pump :BigGrin::Wink:
    terry
  10. Craig Rogers
    Nov 9, 2011
    651
    411
    Cheers all, it's still under warranty and is due a hab check soon, so I think I'll save my effort and get them to do it! :Laughing:
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,758
    6,253
    South yorks
    My monies on the pump seals :thumb: but check everywhere for leaks now,don't leave it to chance or a least turn off the pump :thumb:Wrap all joints and lower parts of any pipes in loo roll then turn pump on,leave until you are primed a couple of times then check the loo paper :Wink:if all dry it is the pump.
    terry
  12. Craig Rogers
    Nov 9, 2011
    651
    411
    It's currently sitting empty at the moment, but I have my suspicions on the draindown valve being slightly open.
    However, it's bugging me that I don't know, so may have to put a small fill in and watch.
    I assume by "pump seals" you mean the seals on the feed, output and filter?
  13. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    5,982
    9,178
    Wrenthorpe, Wakefield.
    We had exactly the same problem.
    Ours was the outside shower hose attachment. We hunted high and low inside the motorhome .
    We only found it when an icicle had formed out side. Luckily it was well below freezing at the time. Or we could still be looking for it.
    • Like Like x 1
  14. spannermanwigan
    spannermanwigan Read Only Funster
    May 22, 2008
    394
    207
    wigan, lancs
    HERES A TIP
    Too protect the drain down valve from being accidentally operated
    I cover mine with a plastic aerosol can cap,with a slot cut in opposite
    sides to allow it to sit over pipes, cheap and effective.
    Allows you to store stuff around the valve without fear of operating it.
    regards
    Steve:thumb::BigGrin:
    • Like Like x 2
  15. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,941
    West Norfolk
    We once lost a whole tankful of water when a toolbox knocked against our boiler drain valve in our old Elddis!
    We arrived at a wild camping spot dry!
    It might be a sliver of limescale jammed in your valve Craig.
  16. ericonabike
    ericonabike Read Only Funster
    Jan 19, 2012
    430
    267
    Leicester
    Just to hijack this thread...
    ...very slightly. We have had the occasional 'jug/chug/jug' noise in our new to us motorhome since we bought it. Thought at first it was the fridge starting up, but now seems more likely it's the water pump. Only happens for a split second, once every few minutes. After reading this thread, seems there may be a leak somewhere? Hadn't actually realised the system is pressurised...
    I've still got two months left of the six month warranty, but would like to be certain what I'm saying before getting back to the dealers. Are there any simple tests I can do to pin the cause and problem down?
  17. rangitira
    rangitira Funster
    Jun 30, 2010
    6,376
    13,164
    Cornwall
    Spect this is the reason take a look underneath:thumb:
  18. Craig Rogers
    Nov 9, 2011
    651
    411
    I think it maybe the drain valve. I filled and checked all pump joints and pipe joints and they are all dry but the pump continues to prime every 10 or so mins.
    Another thing I've noticed is that the bathroom tap doesn't have a lot of hot pressure but find think its related.
  19. Terry
    Terry Funster
    Dec 27, 2007
    10,758
    6,253
    South yorks
    Do as I said in previous post and check for leaks :thumb:IF NO leaks then the only thing left is the pump seals :thumb::Doh::BigGrin:
    terry
  20. Craig Rogers
    Nov 9, 2011
    651
    411
    Well, getting closer.
    After the pump being off all night and all day, I turned it on and it primed, then about 2 mins later it kicked in for a second and then again about 4 mins later.
    Checked all the joints and there is no water leak anywhere, so I removed the pump and found the following on the body that looks like there may have been some water coming out at some point;
    [​IMG]
    [​IMG]
    So I stripped it all down and the diaphram is a little gunked up so thought I'd get all the rubber out and replace, but when I checked, it's far cheaper to just buy a new pump at around £40.
    So, I'm cleaning all the seals up and rebuilding to see if it works first before splashing out.
    If anyone is interested in what a diaphram pump stripped down looks like (the seals are shown bottom right);
    [​IMG]
    It's going in for a Cab service on Friday, so might not get around to refitting it until the weekend, but I'll let you know.
    • Like Like x 2
